Results 1 to 2 of 2
Thread: oil leak
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    Default oil leak
    hey guys
    i have an oil leek from the banjo bolt that hooks the turbo oil line to the motor i have replaced the copper washers but it still pisses out oil what else could be causing this? btw its off an sr20det
    Reeece
    Casula
    try 2 copper washers on the bottom.. Or maybe the line has a grove in it not sealing washers to body.. Had same problem
  • Similar Threads
    1. i think i have a boost leak
      By fergie in forum Technical - Questions
      Last Post: 21st February 2012, 06:46 PM
    2. Oil change -> Oil leak problem
      By Driftspec in forum Technical - Questions
      Last Post: 26th November 2009, 04:12 PM
    3. Serious 4AGE oil leak
      By Golberg in forum Technical - Questions
      Last Post: 21st July 2008, 12:22 AM
    4. Dizzy oil leak
      By wide s13 in forum Technical - Questions
      Last Post: 26th May 2006, 10:02 AM
    5. how to clean oil spill or leak in drive way?
      By johl in forum General Topics (No Technical Questions)
      Last Post: 18th April 2006, 07:50 PM
