You need to grab some RA60 struts, brakes, steering arms, everything basically from a power steering model RA60 or SA63. 25mm shorter steering arms will give you faster steering and more lock, you'll get vented discs too.
Options for front camber are simple, get some 2nd hand S13 cambertops they will bolt straight in.
Best to spend a bit more and get some RCA's also (currently getting numbers for group buy)
