Results 1 to 3 of 3
Thread: clutch bleeding help
    hey there ppl
    ok i tried bleeding my clutch, i've done a few cars before first time on 86 cant imagine it be different
    however, this is the prob, i pump pump, HOLD, undo the nipple, and it just just only drips out (like one drop of fluid)
    so i was think wat the, i left the nipple loose and pump the clutch to see if it shot fluid out with some pressure, however it didnt do anything, reason why i bleeding clutch is because its mega soft, do you think the clutch MC is leaking ? i cant see fluid behind it.
    this is like my 3rd time tryin, the first 2 times it did same thing so then i cleaned the line and it was all rusty and crap inside the clutch line it also had chunky brown old shyt in the reservor too, much better now after a quick clean
    any ideas what this prob could be ?
    Dave
    The Ghetto
    how much fluid is in master... master could be fucked als o what is condition of fluid ?
    Mar 2006
    Sounds like your MC is stuffed.
  1. Trouble bleeding brakes..
    By adds in forum Technical - Questions
    Last Post: 30th December 2012, 05:56 PM
  2. Tips on bleeding your brakes
    Last Post: 14th March 2012, 01:05 PM
  3. S13 front end in an 86 .... brake bleeding issues?
    By ghettorolla in forum Technical - Questions
    Last Post: 30th July 2011, 05:17 PM
  4. 4age coolant bleeding screw
    By lost86 in forum Technical - Questions
    Last Post: 14th June 2010, 02:40 PM
  5. Bleeding brakes with a dry MC?
    By Moebius in forum Technical - Questions
    Last Post: 3rd March 2009, 06:57 PM
