Results 1 to 9 of 9
Thread: what is the general consesis
    Senior Member doony's Avatar
    Dan
    Default what is the general consesis
    with "project MU" rotors and pads
    is it worth the extra money over your standard slotted items.
    be it toyota or nissan etc.
    has anyone got them on there sprinter, ke etc.
    what are they like under hot temp etc
    look forward to anyones feedback.
    Or driving in a wolf pack.
    Akio
    Mt Haruna
    Japan
    they are as good as any race pad and similar quality to wilwood, alcon etc.
    just a jap brand and fucken expensive for what they are.
    so many much cheaper options that work just as good or better for a lot less price.
    Klutch
    *consensus
    Dan
    stfu. hhaahah
    has anyone used these in track based cars?
    or anyone suggest a high quality rotor/pad combination ?
    Ken
    Spearwood
    Using the D1spec Mu pads on the rear atm. Their good for handbrake/brake jabs, but you wouldn't use them for racing where there is longer periods of stopping, as the D1spec operate at a lower temperature then other usual brake pads and would probably start fading pretty quick if you tried to use it in that way.
    Veteran slydar's Avatar
    Dimitri
    i wouldnt buy them in australia untill youd tried the qfm ect seeing the huge price and availability difference.
    i dont think youre gonna notice any performance difference as far as rotors.
    only time id run them is as in kens case, jdm disc rear and i wanted my hand brake to work for drift.
    78's
    Dan
    thanks ken,
    QFM??
    Senior Member Moebius's Avatar
    Christian
    Aaron
    hey doony i also use the d1spec in the disc rear end. they're pretty good.
    also using type nr for the front.
    first time i locked it up almost sent my gf thru the front window. the car just stopped dead
  1. General over asked questions
    By Mille-16i in forum Technical - Questions
    Last Post: 17th August 2012, 10:29 AM
  2. General paint question
    By ae86 in forum Technical - Questions
    Last Post: 1st December 2010, 09:25 AM
  3. general casting ideas
    By redsprinter in forum Sydney & NSW Events and Discussion
    Last Post: 8th September 2009, 05:39 PM
  4. General Info.
    By eightsixboy in forum Technical - Questions
    Last Post: 2nd January 2006, 07:15 PM
