Results 1 to 10 of 19
Thread: 16V ITB Conversion
    Jack
    Nsw
    North shore
    Default 16V ITB Conversion
    The title is pretty obvious and now time for a noob question:
    What do i need?
    I have the 20v black top quads.
    The t3 adapter plate for my bigport is on order
    along with the vaccum plenum and gold velocity stacks
    What else will i need?
    i was reading and trying to research this and came across the phrase tps
    now im getting worried
ID:	2851   Click image for larger version.
ID:	2852   Click image for larger version.
ID:	2853   Click image for larger version.
    A
    Parky
    the tps, throttle position sensor is on your quads,
    but you need a plug to make it work.
    You will also need to get vaccum lines and T peice connectors.
    Jack
    Nsw
    North shore
    thanks any idea where i can get one?
    amything else you can think of people that im missing i just want to give the guy the parts
    and tell him "1 week"
    lol
  • #4
    User fantapants's Avatar
    Pat
    meh do it urself ... not that hard really... plenty of threads on how to floating round
    06/07/2011
  • #5
    Paul
    http://www.twincam.info/index.php?showtopic=26291
    from another forum, but this may help you
  • #6
    Jonathan
    From what you have in the picture, you only need the throttle bodys themselves. You also have there in the picture the 20v intake manifold, which contains the balance tubes and injectors. You don't need this, but don't throw anything away.
    Doing the conversion, there is some stuffing around making the throttle cable setup. It gets hard if you are missing some of the linkages. And even harder if the throttles are mounted up-side-down, which some manifolds do. KE70 or KE55 throttle cable should work either way.
    I take it you already have a aftermarket computer? This is needed.
  • #7
    Jack
    Nsw
    North shore
    Wait i get it lol
  • #8
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    side note>
    how hard is it to tune these? (assuming u have some sort of aftermarket comp)
  • #9
    Jonathan
    Easy and hard. "Tune" can mean so many different things. If the computer is wired up 100% and the motor is good and connected to water and oil etc... and you are left to only do the software tuning... it should be easy. But then again, if you have some software bug or unknown problem, it could take weeks or only seconds to sort out.
    As for quads vs single throttle, not a big problem. Easy enough to tune.
    The problems are:
    1. having the throttles bolted on the motor with no vacuum leaks.
    2. having all 4 throttles in sync, closing and opening together. Getting full throttle, and snapping closed for idle.
    3. Getting an accelerator cable the right length, no friction, to provide full throttle plus idle. Can be tricky to set up at times. Sounds simple.
    4. TPS wired to ECU. Calibrate ECU for new TPS.
    To get an idle, you can choose to have the throttles cracked open slightly. Or you can choose to have the throttles snapped shut, and screw the air bleed screws all the way out. All 4 or them. Or, you can run a factory idle speed motor thing connected to your vacuum chamber, controled by the ECU.
  • #10
    Jaidan
    Adelaide Hills
    cheers jonny! always wanted to got quads but the tuning always sort of held me back
    btw i have a smallport bottom end and a big port head and want to keep a street set up (ie more more response/acceleration than top end) would u suggest leaving the cams for now or should i look into getting some at the same time?
    >sorry for the hijack
  • Page 1 of 2 1 2 LastLast
    1. 16v Smallport w/ S/T ITB's
      By 08ftwyo in forum Technical - Questions
      Last Post: 20th May 2012, 10:22 PM
    2. qauds/itb on to my 16v, how?
      By toddheart86 in forum Technical - Questions
      Last Post: 13th September 2011, 09:50 PM
    3. Wtb: 16v itb adapter
      By DR86FT in forum Cars or Parts Wanted
      Last Post: 21st July 2011, 10:12 PM
    4. 16v itb from silvertop
      By DRFTPG in forum Technical - Questions
      Last Post: 23rd October 2010, 09:18 AM
