yes, taking the dash board out will make it ten billion times easier to do.
just a quick question
do you have to take out the complet dashboard to take the pedal box out, if not how do you take it out
:fap:
Its a cunt of a job.
pictures might not work i dunno.
i dont think its as bad as people make out. just drop the steering column, two bolts and thats down. then you unbolt it all and it comes out pretty easy.
^^^^^ you haven't even tried to take a pedal box out have you^^^^^
becauce thats what i thought untill i started to take it out for real
It is honestly easier than most say it is.
No need to take the dash out at all, as long as you are willing to work upside down and get your hands into some tight spaces.
when i tried to get it out, it kept getting caught on the wiring loom.
ended up ripping the dash out in the end, made it that much easier to do.
Like Javal said, as long as your willing to work upside down its just a bit fiddly. Take the drivers seat out so you can lay down properly in there. We ended up using a hole saw to punch through one of the fan ducts to get the final bolt out as it was a bitch and we didnt wanna take the whole dash out. Just be patient and be willing to spend a bit of time on it!
i did that :lol:
alright i will try to get it out with out taking the dash out
i take back what i said it is possible to take it out with out taking out the dashboard i just did
