Results 1 to 5 of 5
Thread: Dodgy AE86 Headlight Switch unit
    Default Dodgy AE86 Headlight Switch unit
    Heyas,
    So for the second time, the headlight switch/dash dimmer rheostat unit in my AE86 is failing on me. Last time I just replaced it with a 2nd hand unit, which worked a treat for a year until now. It's displaying the same issues, which is basically turning my headlights off randomly (whilst driving) and sometimes refusing to turn on again until I bash my dash fonzie style.
    I have temporarily fixed this issue with cable ties (should've taken a photo, its sweet).
    Anyways, I remember ages ago skimming over an article in the old forums that I believe fixed this issue by soldering the busted contacts within the unit itself. Anyone happen to have the thread handy?... or any other ideas?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    mine was wired to the window wiper switch....
    FTP.
    Take it out. You will see 2 wires that go to the dim adjusting part, cut them and join them. It will never go out again, but will always be on at its brightest.
    Mt Macedon
    This is a common problem. There's a bunch of writeups out there on how to fix it properly. Mine has been working for 5 years now after fixing.
    Anthony
    the problem is dry joints on the switch pcb. you need to reflow these solder joints, or get someone to do that for you. then you'll get many more years of service.
  1. ae86 headlight switch problems.
    By sprinter666 in forum Technical - Articles
    Last Post: 22nd July 2010, 10:36 PM
  2. ae86 headlight switch
    By sprinter666 in forum Technical - Questions
    Last Post: 14th January 2010, 07:15 AM
  3. ae86 headlight switch
    By sprinter666 in forum Cars or Parts Wanted
    Last Post: 10th January 2010, 08:08 PM
  4. WTB: AE86 light switch unit
    By hao. in forum Cars or Parts Wanted
    Last Post: 16th August 2009, 12:09 AM
  5. headlight switch ae86
    By irl86 in forum Cars or Parts Wanted
    Last Post: 10th August 2009, 09:38 PM
