looks good so far keep up some good work
dont be afffraid to ask for help !
the dyno pull to 300rwkw
hey bonnie its hally (tyson) how u been havent run into u for a while haha,u can fix bars by heat gunning them and pushing it out etc then get plastic bog,and the crak u can plastic weld it by using the same plastic with a mini gas torch and yer bit hard to explain sorry lol just stitch it much easier
catch up
Old username : hally
Beige build in the works!!
http://www.ae86drivingclub.com.au/fo...426#post874426
Got the last coat of primer on and lights in, still had ae71 rad support and was stoked not to have to make up brackets, and with the shoddy wiring managed to get all my lights working! yay! Getting it on the road is getting super close now!
Thanks Jeff for the hand sanding
and Hey Tyson, yeah looks like i need to invest in a heat gun at some stage!
Hey mate........its not hard to fit the bumpers on.....
just either bend the reo bar back a little or cut about 1/2 an inch of the front.....( if reo still attached)
then cut the top corners of the 86 front bar to allow it to slide all the way on and reach the wheel arch.....
for the rear you just have to cut about 1/2 an inch off the top lip to allow it to reach rear wheel arches......
Then a few screws in the right places and there you have it
you can also use a hot melt glue gun to fill the cracks in the bar (very cheap item from a hardware store) Then sand back and paint....
ah thanks, yeah it looks as thought there is a bit of cutting and mashing as it sits way too far out with the reo bar where it is.
and glue gun you say... hmm that fits the budget but is the glue strong enough to bond it properly??
Looks good with the lights back in. Is the interior super mega crazy dusty from the primer?
J.
it's looking like a car again, awesome!!
bonnie please dont go sprinter front
just use good condition bumpers and will look much more sleeper
should be fun once done
