Results 1 to 7 of 7
Thread: 15X8 -4 offset on ke70
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    Default 15X8 -4 offset on ke70
    As per title
    would guard work be required?
    and how much guard work,
    also anyone got pics with this size or similar be cool if you could post em up
    -Alex
    Formerly known as grape_moosha
    Site Supporter Javal's Avatar
    Josho
    Flared guards. some people get away with rolling them.
    Fitment on wookiecar ages ago.
    Front with 15 x 8 -9
    Rear with 15 x 10 -27
    Veteran Konakid's Avatar
    Henry
    Eastern
    That top pic is with adjustable lower arms and -3 camber though.
    If you are running the car low, i.e above cars height, you will need on the front a flared guard, camber (-2 or so from camber tops)
    The rear will need a roll and a bash but may still rub depending on height and spring stiffness.
    I'd personally go 15x8 0 offset superlights to give that bit more clearance.
    With 195/50's of course.
    Alex
    Northfield
    ah so superlights come in 0 offset.
    thought it was just -4.
    cheers for the info, its for a mate who just got a granny spec ke, he has good plans for it
    Nigel
    Yeah, they make a -4 and a +4, I'm running the +4's on my sprinter.
    Don't reckon they make a 0 offset tho.
    West
    If you don't touch the gaurds they will be a half inch out the gaurds at the front.
    The best fitment for handling (closest to the strut) and to require minimum flare (with Corona Arms) probably about 15x8 +8. Im running 15x7.5 + 20 and they sit nice and close to the strut and near fully fill my flared gaurds. 15x8 +8 will have the same backspacing.
    For the rear, with a lot of lipping I got 15x7 +1 on there. So in 15x8 youd be looking at +25 to fit the same way.
    If you buy a full set of those rims in 15x8 zero or -4 you will have a hefty need to flare both front and rear.
    Henry
    Eastern
    Yeh i meant the 8 +4 if you want to do minimal guard work, not zero.
  1. 15x8 0 offset
    By hillzy in forum Technical - Rims & Tyres
    Last Post: 29th July 2012, 11:12 PM
  2. 15x8-0.offset
    By oldman in forum Car Parts For Sale
    Last Post: 21st May 2012, 10:28 PM
  3. 15x8,8.5,9 -20 offset onto ke70
    By sleeper_13 in forum Technical - Questions
    Last Post: 10th April 2012, 11:19 PM
  4. JDM offset 15x8 and 15x8.5 drifting wheels!!!
    By skizzamods in forum Cars for Sale (Toyota Only)
    Last Post: 15th January 2011, 05:16 PM
  5. 15x8 - 15x9.5 With neg offset!
    By gumbie in forum Cars or Parts Wanted
    Last Post: 24th July 2009, 06:49 AM
