Results 1 to 10 of 12
Thread: how to Wire up the Narva kit
    Veteran corknose's Avatar
    Callum
    Default how to Wire up the Narva kit
    well i bought some quad lights and came with a Narva kit for the spot lights and just wanted to know how to wire it up???
    cheers callum.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    so youve got a qud headlight conversion for a ke70? or you bought spotlights to do it?
    because if they are genuine quad headlights they are a plug and play order. just need to cut and join new wires and wire them to the same pins on the other head light
    FTP.
    Callum
    ohk yeh so do i just need to like piggy back them off the original wires
    Clinton
    Tweed Heads
    yeah. basically.
    thats if they are genuine items. what are you talking about narva spotlight harness for?
    FTP.
    Callum
    ive got no idea what ur saying really,,, but its just like that 3 prong plug and its just got some wires coming off it so im ask how to makke them work,,or can i just hook them up so they are like my high beams
    Jonathan
    Basically, any headlight, driving light, fog light, should be powered dirrectly from the battery via a relay and a fuse. The way you hook up the switch to power the relay can change a lot to what you want.
    Callum
    yeh im thinking of making a switch just for the spot lights thanks heaps
    E-Famous (Remeber your roots)
    This should help.
    Callum
    Hmm bit not really can't see on my phone very well but I think I'm going to make just a switch in the cabin for the spot lights,, what's the half re and black cable is that like ground or something ?
    Clinton
    Tweed Heads
    get a test light from repco for $10. the best auto electrical tool you can buy for $10.
    FTP.
  1. Replies: 6
    Last Post: 5th September 2010, 09:38 AM
  2. 1 wire or 2 wire o2 sensor?
    By Clinton in forum Technical - Questions
    Last Post: 20th November 2009, 08:27 PM
  3. 3 and 4 wire distributers
    By --Redwork-- in forum Technical - Questions
    Last Post: 14th March 2009, 09:18 PM
  4. tacho wire
    By deanoo in forum Technical - Questions
    Last Post: 16th June 2007, 06:19 PM
