Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: bigport or smallport
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    hey guys,
    i thought i knew but now i am confused...
    How do i tell a bigport from a smallport?
    thanks,
    J
    Bigports have TVIS, smallports don't, that should be the easiest way to tell.
    Bigports should have a smooth plenum top, and the smallports have ribs on them like a heatsink.
    If the manifolds have been changed this will not work of course, but you can also tell from the cooling system setups.
  • #4
    Jul 2009
    Kane
    Coburg
    as andy said^
    or
    if its apart check the port sizes
  • #5
    JoJo
    ACT
    Tuggeranong
    can i put a manifold off a bigport on a smallport?
  • #6
    JoJo
    ACT
    Tuggeranong
    inlet that is.
    I know the exhausts are interchangable..
    can you get a 100kw motor in big or small port? I thought it was only bigport but someone told me differant and confused me.....
  • #7
    Jul 2009
    Kane
    Coburg
    can i put a manifold off a bigport on a smallport?[/b]
    you can buy an adaptor for about 200
  • #8
    Veteran driftism's Avatar
    Andrew
    Watsoia
    the 100kw motor from the factory was a smallport.
    the bigports came in 2 main variants:
    JDM 96kw
    ADM 86kw
    you can fit a bigport inlet manifold to a smallport with a T3 adaptor plate
    http://www.technotoytuning.com/productdetail.php?p=374
    hope that helps.
  • #9
    smallport has oil drain pipe at the back of the head
  • #10
    Mar 2006
    WAT JDM BIG PORT HAS 96kw??? u sure ???
  • Page 1 of 3 1 2 3 LastLast
    1. Bigport or smallport cams
      By DearmanKE in forum Technical - Questions
      Last Post: 13th April 2010, 11:30 AM
    2. Bigport or smallport?
      By dunga70 in forum Technical - Questions
      Last Post: 9th April 2010, 05:41 PM
    3. smallport bigport?
      By 86TRD in forum Technical - Questions
      Last Post: 30th July 2009, 04:00 PM
    4. bigport or smallport
      By .ady in forum Technical - Questions
      Last Post: 26th April 2009, 09:57 PM
    5. Can I use my Bigport loom on a Smallport?
      By jet111 in forum Technical - Questions
      Last Post: 3rd March 2009, 07:24 PM
