Results 1 to 10 of 16
Thread: I want my quads looking like new
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default I want my quads looking like new
    Does anyone know of any products/ways to get 20v quads looking fresh and un tarnished... besides degreaser and wire wheels...?
    there is too many hard to reach places for a wire wheel.
    Can they be acid dipped? or are there parts that would not handle this so well on them?
    Just want them looking clean as possible, my efforts so far fall short of what I want.... thinking of painting them also so they defiantly need a better clean...
    Cheers for any worthy suggestions
    BENT MECHANIX - Garage 20:
    Senior Member Dylan's Avatar
    Dylan
    acid dip as in hot tank?. Wouldnt recommend it
    I suppose sandblasting is an option but would require them to be stripped bare.
    Niz
    South~Slide Briz
    yeah I was pretty skeptical on acid dipping them, but wasn't sure as I have never had anything done this way, so not sure on whats capable etc. . .
    Thats the other thing, I want to keep them as one only removing the vac lines and sensors ect (non metal parts)
    Steve
    Powder coating them, maybe, if its a fresh look your after.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    petrol?
    FTP.
    Veteran shift_rook's Avatar
    SE Burbs
    if degreaser doesn't work then petrol won't um, try brake cleaner, fuckin harsh stuff, if there's any dirt on them it'll get it off
    Senior Member Vizz's Avatar
    Adam
    Biloela
    Sandblasting worked really well for me
    http://www.ae86drivingclub.com.au/fo...ead.php?t=3357
    mine were only partly dissassembled, it should be fine just removing all the vac lines and sensors as you had planned.
    1983 Sprinter making progress
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    plastic media blasting or soda blasting both work great and wonr need them to be stripped down
    the dyno pull to 300rwkw
    carby cleaner is stronger than brake clean.. can give that a go.
    Akio
    Mt Haruna
    Japan
    baking soda, little bit of dishwashing detergent, little bit of water, toothbrush and start scrubbing.
  1. quads throttles
    By AEA-386 in forum Technical - Questions
    Last Post: 3rd April 2009, 10:34 AM
  2. Replies: 20
    Last Post: 21st February 2009, 12:52 AM
  3. I WANT QUADS
    By 4AGE - 86 in forum Car Parts For Sale
    Last Post: 30th January 2008, 08:45 PM
  4. putting 20v quads on 4age quads
    By w84me in forum Technical - Questions
    Last Post: 24th September 2007, 09:33 PM
  5. 20valve quads
    By samuek in forum Car Parts For Sale
    Last Post: 24th May 2007, 10:16 PM
