Results 1 to 9 of 9
Thread: Full lock question ?
    Default Full lock question ?
    i get 2 full turns on the steering wheel to the left but only 1 1/2 turns to the right whats going on?
    the guy who i bought the car off had put RA60 front stuts in is there something he might not have done right resulting in this?
    please help U turns are starting to piss me off!
    Jonathan
    You need a trolley jack and 2 jack stands. You can get a creeper also, but a large peice or cardbourd is my favorite.
    got these things but how does that solve problem?
    Jonathan
    So I gather you got under the car and had a look?
    sounds like he installed a lock spacer as you have a total of 3.5 turns. find the centre, take steering wheel off and reposition it. adjust toe so its "straight" then go get a proper wheel alignment
    Senior Member stylz's Avatar
    Art
    Melb
    ive got a similar problem, but thats because on of my wheels hits the wheel arch. even after a full alingment it does that :s
    性交を愛する
    Rack needs to be centered.
    marvis.
    Jonathan
    Measure the effective length of a steering tie-rod, from ball joint to ball joint. Adjust them so they are the same length either side. Or count the number of threads showing on either side, and make them match. This is what is ment by centreing the rack. Then with both front wheels positioned so they both have the same amount of toe, pull the steering wheel off and put it back on straight. With the steering wheel kept in the staight position, adjust toe-in to about zero.
    If you then have different steering angle turning each way, the tyre is hitting something.
    thanks for your help guys much appreciated ive never had to deal with this sort of thing before got to love the 86
  1. Extra lock question?
    By Alexrex7 in forum Technical - Questions
    Last Post: 1st October 2012, 10:34 AM
  2. S13 suspension: tie rod end hitting LCA at full lock
    By evil86 in forum Technical - Questions
    Last Post: 26th January 2010, 02:03 PM
  3. rock the full lock!
    By ae86 in forum Offtopic Discussions
    Last Post: 12th January 2009, 11:28 PM
  4. Abnormal loud noise on full lock
    By Loopy in forum Technical - Questions
    Last Post: 11th August 2008, 04:43 PM
  5. Rubbing on inner guard @ full lock
    By Andor in forum Technical - Questions
    Last Post: 17th January 2007, 07:18 PM
