Results 1 to 8 of 8
Thread: Best spark plugs for 4agze?
    Hugh
    Default Best spark plugs for 4agze?
    Hey guys,
    as title states, just about to get mine up and running, so hoping to find out what others think is the best, will be running a pulley kit (cant remember the size) came off Tom (nikkojoe) and he said was pushing 13psi with a front mount...
    Also, where to find/ part numbers would be very useful.
    Cheers in advance
    Veteran Nikkojoe's Avatar
    Tom
    I was just running standard bigport sparkplugs with mine.
    NGK BCPR5EY11. Also made 14psi with the front mount (on cold nights). Size of pulley is 178mm (or there abouts).
    BCPR6EP-N-8 is the recommended plug though
    Reeece
    Casula
    go for the colder plug with boost
  • #4
    Senior Member Moebius's Avatar
    Christian
    4agze should run 0.8mm gap, so whatever plug you get BCPR etc just make sure it has 8 at the end.
  • #5
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    always run bcpr6es plugs in ze turbs and sr20
    AE86 THE BEST
  • #6
    Nic
    Mt Evelyn
    is this plug good for a 4agte running induvidual coils and an LT10s microtech??
  • #7
    Eddie
    sa
    dosnet matter always use bcpr6es work excellent, in my na's 4ag turbos and sr20s!!
    AE86 THE BEST
  • #8
    Alistair
    Cleveland
    NGK ftw
  • Similar Threads
    1. Spark plugs
      By Figgy in forum Technical - Questions
      Last Post: 21st April 2010, 10:20 PM
    2. spark plugs
      By sprintdaddy in forum Technical - Questions
      Last Post: 4th May 2008, 02:43 PM
    3. Spark Plugs
      By stouty in forum Technical - Questions
      Last Post: 22nd November 2007, 05:46 PM
    4. 4AGZE spark plugs Mis fire issue
      By D1 in forum Technical - Questions
      Last Post: 15th January 2007, 06:02 PM
    5. what spark plugs do you use??
      By jeenyus in forum General Topics (No Technical Questions)
      Last Post: 20th April 2006, 12:12 PM
