Results 1 to 6 of 6
Thread: rwd 3sge. What dizzy???
    c
    Default rwd 3sge. What dizzy???
    A mate and i are putting a 3s in his 71 and were just going to mount the engine forward so the dizzy will clear the fire wall.
    But i was curious as to what others have done to change the dizzy so the engine can be mounted further back?
    Iv heard that you can use the internals of some sort of mitsubishi dizzy mated to the 3s one to run external coils with a ignition ecu.
    Jonathan
    Leave the 3S-GE dizzy in there, just take the cap and rotor off. Then make a low profile cover for it on the lathe.
    If you already have a aftermarket computer, it will be easy to run 4 coils, or two twin coils, or 4 coil-on-plug things.
    Then you have to remove all the rear water housings also and modify that setup.
    One mate mounted the motor a fair way back, and kept the dizzy cap and stock water setup, and just cut his firewall heaps. It is a nightmare to work on, don't do this.
    Mount the motor in a normal position, low profile dizzy cover, 4 coils, modifyed water setup.
    Veteran slydar's Avatar
    Dimitri
    "a 3s"
    there are 5 versions.
    a gen 1 has quite a "tall" dizzy. if you mounted the engine so far forward it didnt hit the firewall, in a 71......
    gen 2 is lower profile and will fit a gen 1.
    dunno about the gen 3.
    everything else is cas/cop
    ill be running a gen2 dizzy in my gen1 with a low profile cover replacing the dizzy cap and coil on plug.
    78's
  • #4
    Andrew
    Gen 3 dizzy is nice and low profile too, not sure if it will fit gen1 but i'm happy to measure mine if you need me to.
    I've converted to front mount distributor on mine as it makes it easier to retain the stock computer that I need for engineers certificate. Also quite a bit cheaper than COP.
    I can take some pics after easter if you like?
  • #5
    c
    slydar: its a gen1 sorry i thought i posted it up. Will you be running a stock ecu?? or igniton ecu?
    I had noticed that the dizzy was very tall hence the question
    af300e: Pics would be sweet. Did you make the brackets to mount the dizzy?
  • #6
    c
    now just looking at running a razorback ecu with the modded stock dizzy as mentioned by johnny and slydar
  • Similar Threads
    1. Converting a 3sge to RWD
      By biggo in forum Technical - Articles
      Last Post: 29th December 2013, 09:26 PM
    2. tarago diff and rwd 3sge stuff
      By old_school_jap1 in forum Car Parts For Sale
      Last Post: 22nd February 2010, 10:16 AM
    3. Gen3 3sge RWD corolla in SYDNEY
      By gottago in forum Cars for Sale (Toyota Only)
      Last Post: 25th October 2009, 11:06 AM
    4. 3SGE RWD parts
      By 20valve69corona in forum Car Parts For Sale
      Last Post: 10th April 2009, 10:24 AM
