Results 1 to 8 of 8
Thread: removing headlight glass
    Oldschool Member
    Apr 2007
    hi, i have an idea that might just work if im able to remove the headlight glass. can someone help me out removing it or tell me some steps to remove the glass without making it crack
    Veteran Nikkojoe's Avatar
    Tom
    Step 1: Take off both clips on side of lense
    Step 2: Get hair dryer out and warm up the edges of the lense (make sure the glass is atleast warm when you touch it)
    Step 3: Begin to wedge the lense off slowly with a small screw driver (if still not budging much or sealant is very stringy, heat up more with hair dryer)
    Step 4: It should be off
    Installation is the reverse of the above steps, except when putting it back on make sure you heat up the sealant.
    Aug 2007
    You can put it in the oven at a low temp, about 70 or so and leave it in for 5 min try put a screw driver under the glass at the deepest point. If it doesn't come out easy put it back in the oven for 5 mins. Don't just put the screw driver next to the glass and try twist the screw driver to get it out you will chip the glass!! I seriously done it 20 mins ago lol Hot water also softens up the glue stuff holding it on.
    Elite rthy's Avatar
    Leo
    Tulla
    just curious whats your idea
    Veteran GAKI86's Avatar
    Dave
    Broady
    another thing you have to work fast...
    placing back the glass is gay when it hardens..
    pair rusty trueno guards
    2x trueno headlights
    pair trueno guard indicators
    rally zenki trueno front bumper
    kouki trueno front bumper
    zenki flip grill
    2x trueno grill
    pair zenki ae86 seats
    Heatgun + Screw Driver
    Heat it up, pop it out. Who cares if it drys. You heat the glue up again and the lens. And put it back in..
    parrot
    I have just taken one of mine off this morning and used a heatgun and a flat blade scraper to lever it out from the top.
    I wouldn't use a screwdriver.
    Go gently and cut the sealant with a razor blade as you go.
    'Red_Hachi_Box'
    I did this just an hour ago swapping my glass over for a un-damaged one, put it in the oven at 150c for 3 minutes and break the seal with a flat head screw driver at the corner, leavered it up and off.. used another second flat head and keep leap frogging them and levering it off bit by bit.. Easy!
    Reheat for 3 mins when putting it back on, then put glass in place.. Another 3 mins? gets the sealant back into stick and seals it.. Done!
    Good luck, Dillon
  1. Removing quarter glass and plastics?
    By stefan in forum Technical - Questions
    Last Post: 7th April 2011, 11:09 AM
  2. Glass OFF!!
    By Rice86 in forum Technical - Questions
    Last Post: 28th March 2009, 03:04 AM
  3. HeadLight Glass Removal
    By Medwin_3sGTE_AE86 in forum Technical - Articles
    Last Post: 27th January 2009, 10:35 AM
  4. help needed to removing glass for hatch
    By loc33e in forum Technical - Questions
    Last Post: 12th February 2008, 09:13 PM
  5. removing hatch glass
    By Klutch in forum Technical - Questions
    Last Post: 24th August 2006, 01:00 AM
