sponsors section y0
i have the following for sale,
all located in tasmania
1. ae86 strut tops,
needed for 86 unless you want to redrill the holes
working condition, bearings are ok
$50
2. ae86 ADM callipers
upgrade from ke callipers
include pads but they are fairly low, could use a seal kit.
$80
3. std panhard
keep your diff from wandering when you turn
has one replaced bush, nolathain be belive
$ offer
4. T-50 shifter
needed to change gears with T-50 box
working condition, bush intact
$30
5. std rear springs
suit ke70 ae86 etc, good for passing rego, nice and high
uncut striat out of the car.
$15
6. ke70/ae71 callipers
suit someone who needs some
was in a car about months ago, comes with alright stock pads
$15
7. boash 4ac leads
carries spark from the distributor to the plugs
was in a running car resently
$10
8. ke70/ae71 tinted rear lenses
pimp out your E7
no cracks has some cratchs in the tint paint
$ offers
9. ke70/ae71 coil
makes sparks for 4ac, 4kc 3tc etc
was in a running car, upgraded to electronic
$10
10. steering cloum surround plastic
suits E7
tan in colour, not cracks or chips
$10
11. 4ac std carbs
complete
$10 each
12. 4ac altenator
working condition
$25
13. lots of other 4ac bits
dizzys (1 with new cap and rotor button), flywheel, and heaps of other bits just ask (im the 4ac king)
14. set of wheels
upgrade from steelies win aperance and perfomance
14x6 4x100 pcd +40offset suit a ae80/ae82 well along with many other small FWD cars
inclued 4x 175 yokohama a-spec's with low but legal tread
$100
pics
1.
2.
3.
4.
5.
6.
7.
8.
14.
prices are neg
postage available
sponsors section y0
Do you have a 4A-C crank pulley from an AE80/82??? I need the type with both a v-belt pulley and 5-rib pulley on it, not the AE71/AE86 4A-C type.
hi, you got a water pump in good nick? 4ac?
AE86....robbing me! check the build.
http://www.ae86drivingclub.com.au/fo...read.php?t=445
na this is personal stuff not business so i thought it would be better suited to the forsale section
do not have a 4ag style pulley
yes i do have a water pump, i assume its ok, it was in a running motor until it stopped running. wasn't over heating before the headgasket blew so i assume its fine, quite possibly the original one though.
Just to verify, I'm after a 4A-C pulley NOT a 4A-G crank pulley.
Aaron will have one, pm him
aaron is fairly sure he dosent... i havnt seen this type of pullys that i think you mean on a 4ac before, then again i have never owned a 4ac from an ae82, ae80 have 3ac's dont they...??
this is the only kind i have this which im fairly sure its not the one your after.
wheels added
Nope, not the one. Thanks anyway though.
Need one for another project I have. Oh well. Good luck with the sale.
