Results 1 to 10 of 16
Thread: T50 Question
    Ryan
    Hey yall.
    I know that most people who get a 4agze and eventually turbo them always goto a W Series box, as they are stronger and can handle the stupid amounts of power people like to run - eg: 170RWKW.
    But what i want to know is that if i have a trubo setup.. and im only running mild to low boost.. and making around 115- 120 rwkw as a starting point... will my t50 be okay???
    because i want to do it in stages.. goto 120rwkw.. then get upto 170 when im happy with it all. and eventually goto a W58 box...
    But i think that ill save some $$ and kill hte t50 first... how much power can it handle safely and reliably????
    Ok
    Seamus
    Milton
    Yes it will
    Just don't "snap second" to leave black marks all over the road .. sooner or later you will leave gear teeth all over the road instead
    Treat it nicely, it will live
    ^ Clicky clicky!
    Ryan
    should i have mentioned this is for a track car???
    atm i only drift in 3rd and 4th.. and there's not allot of snapping going on.. ???
    Veteran johl's Avatar
    Johl
    im assuming its the adm t50? my tattoo artist has a hachi with a gze with mild work done to it and i believe he is still using the adm t50 and that car has seen a fair bit of track work. i'd stick with it till it breaks... and it will cuz u will be driving pretty hard. in the end its only a track car so if it breaks ur not gunna be without a car to get to work so whats the harm really?
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    Its more to do with torque output than outright power. Assuming you aren't going to be running insane amounts of low-end torque, the box (if treated with a little mechanical sympathy) should hold out fairly well. Probably run a clutch that will break before the box too (Heavy duty or low-end cushioned button clutch) to try and help out too.
    By track days, you mean drift yeah?
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
    Ryan
    ^^ drift indeed!
    so it will mostly be 3rd gear and 4th gear screamers!
    Jul 2009
    Kane
    Coburg
    if you got the cash to do it, do it now and be done with it yo
    yep It will break!!!!!!
    Ryan
    kkkk
    so i will need a bellhousing..
    a new clutch...
    and possibly change the flywheel??? i would like to keep the 20v one i have...
    i assume that its a custom clutch or possibly just a supra clutch???
    Johl
    u can get a bellhousing to match up to the 200mm clutch n flywheel so u can keep ur gear thats in there i believe. i think the bellhousings r $450 from one of the sponsors on this site... could be wrong about them matching to the 200mm clutch but i think its right? correct me if im wrong?
  1. T50 gearbox filling question
    By ke_70_blue in forum Technical - Questions
    Last Post: 4th December 2012, 08:42 AM
  2. t50 question boys
    By fantapants in forum Technical - Questions
    Last Post: 1st October 2011, 11:36 AM
  3. jdm t50 question
    By pen15 in forum Technical - Questions
    Last Post: 27th March 2009, 10:56 AM
  4. hilux diff t50 and na bigport ANOTHER QUESTION ADDED
    By 350hp4agte in forum Technical - Questions
    Last Post: 13th December 2007, 05:44 PM
