Results 1 to 10 of 11
Thread: Can I place my water temp gauge sender here?
    Junior Member Killswitch's Avatar
    Default Can I place my water temp gauge sender here?
    Hey guys,
    Just wanting some confirmation as to whether or not this is a suitable spot for my water temp gauge sender. It appears to be a coolant bleed, not sure why you'd have it there though?
    Any pros/cons of having the sender here vs off the head or anything?
    See pic. - thread to the right of oil pressure sender.
    Thanks
    Site Supporter Javal's Avatar
    Josho
    Yes it's a coolant bleed / drain.
    You can put it there if you want.
    Sweet as, on closer inspection it seems less than ideal though.
    Where else do people put there temp senders? Just tap a thread somewhere?
  • #4
    todd
    cut your top pipe and fit a temp sender joiner in the gap. then join the pipe back together. screw it stright in and presto.
    can get them from most auto places on request, just have to supply them ur pipe dia. and thread width of the sender.
    think i eve saw some on ebay a while ago.
  • #5
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you can in theory put it in there but it will be no good as it will read lower temps there. You need to have it in the top water outer like todd said. The stock position no good?
  • #6
    Haven't found an adapter yet for the stock position. Only really looked into installing this gauge recently so nothing has been open. Just noticed the thread on my sender was the same as the bolt that goes into the coolant bleed and thought it might be an easier way out. looks like I'll just hunt an adapter down for the stock position though.
    Cheers everyone.
  • #7
    Endeavour Hills
    Autobahn sell a series of VDO adapters, maybe try there?
  • #8
    Senior Member sotiros86's Avatar
    Andrew
    Wollongong
    Supercheap sells them too. Just take the sender with you
  • #9
    Will do! Thanks guys, hopefully they're open tomorrow.
  • #10
    Have just been to the local Autobarn and Supercheap. Neither has adapters. Fail. I suppose that's darwin for you though.
    Might try enzed or pirtek next week.
  • Page 1 of 2 1 2 LastLast
    1. ST 20V water temp sender
      By Futo_gt86 in forum Technical - Questions
      Last Post: 20th July 2011, 09:23 PM
    2. Water temp problems/gauge/sendor??
      By FKN16v in forum Technical - Questions
      Last Post: 22nd April 2008, 11:56 AM
    3. hydraulic jack & water temp gauge
      By seeknsqueek in forum Cars or Parts Wanted
      Last Post: 27th September 2007, 05:49 PM
    4. Water Temp Sender Adaptor
      By jdmcoupe in forum Car Parts For Sale
      Last Post: 21st September 2007, 08:52 PM
    5. Does water temp sender interact with ECU?
      By FullMetal in forum Technical - Questions
      Last Post: 5th March 2006, 09:51 AM
