Aftermarket Computer with Fuel and timming adjustments
Razorback ECU
Features -Adjustable fuel every 500RPM
-Adjustable timing every 500RPM
-Adjustable idle
-Adjustable TVIS/VVT point
-Internal MAP Sensor (can use std one also)
-Supports multi coil
-Hand controller
-View live RPM, Vacuum, Advance of timing, battery, Air temp
TPS position, water temp and more
PLUG AND PLAY SETUP (Yes plugs into existing loom, AE82 and AE86 or SV21
$480 (SOLD)
Will post anywhere
Rick
0421630326
Located in Mill Park, VIC (Pickup available)
