Results 1 to 10 of 14
Thread: what so good/bad when your 5th gear is like a 4th??
    Oldschool Member
    Aug 2007
    As topic!!!!
    Thurston
    Vic
    North East
    in english?
    Veteran blair's Avatar
    Blair
    SEQ
    he means a lower diff ratio i beleive?
    Oldschool Member
    Aug 2007
    What he said (winslow)
    Greg
    Coorparoo
    whats the question though?
    having a HIGHER diff ratio (ie 4.7 as opposed to 3.9) will make your fifth gear seem to be more like your old 4th (as in you will use more revs at lower speeds)
    Jan 2007
    Im thinking direct drive (1:1) 5th gear and shorter ratio's?
    Senior Member SLO-030's Avatar
    Ryan
    Southern 'burbs
    $th is direct drive (1:1) with will be something like .89:1
    If you have changed your diff ratio (from the s series 3.9 ratio to a T series 4.1) your revs will be higher in every gear but more noticable because your cruising. 5th normally only drops your revs by 500rpm max
    bass_2000_au_au@hotmail.com says:
    they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
    Oldschool Member
    Aug 2007
    my Question is: A short 5th gear is it a good idea??....as that ae86 is not for top speed IMO..,,most likely hill climb/drift.
    so a short 5th gear will help hill climb/drift??
    i know this setup will kill the petrol...hehe
    Senior Member quoccy's Avatar
    Peter
    you drift in 5th gear?
    A
    Parky
    you serious mate,
    top of 4th is pretty quick with a 4.1, 3.9 and when would you need to use 5th gear if not just crusing around?
    5th is pretty short anyways why would you bother going to the effort of changing it.
  1. 5th/reverse gear clutch hub or broken gearbox
    By Group A in forum Cars or Parts Wanted
    Last Post: 17th June 2011, 11:37 PM
  2. T50- won't engage in 5th gear and reverse, any ideas?
    By 4.5AG in forum Technical - Questions
    Last Post: 10th March 2011, 10:58 PM
  3. 19th September - CCG Skidpan Day at 5th Gear Motoring
    By jezz in forum Canberra & ACT Events and Discussion
    Last Post: 13th September 2010, 09:01 PM
  4. W58 5th gear weak?
    By Grant #2 in forum Technical - Questions
    Last Post: 9th March 2010, 08:52 PM
  5. Route 6 close ratio 4th and 5th gears???
    By DK86 in forum Technical - Questions
    Last Post: 2nd August 2007, 11:59 PM
