Results 1 to 10 of 10
Thread: JDM rear Disc Brakes - changing pads
    Nov 2005
    Hi all
    Changing pads in my rear disc brakes and the piston is sticking out too much to fit the pads over the discs.
    How do you push them in? or am i missing something...
    Anyhelp/ideas would be nice
    Eddie
    You need to force the piston back... Toyota have a SST (special service tool) to do this but most of us use a screwdriver. Put your old, worn pads back in and use a screwdriver to lever the piston back a bit until you've got enough room to fit the new pads. If it's still too difficult, you can crack the bleed nipple to release some pressure but you'll need to bleed your brakes afterwards.
    Eddie.
    parrot
    Or you can use a clamp which is a bit fiddly as you can't really centre it.
    Be patient and try to get the piston back in evenly, i.e. to much pressure on one side doesn't work.
    Doh! My bad!! See below. Sorry.
  • #4
    Dave
    G-clamp usually works well for me, with the old pads still in there, so you dont push down to hard on one side (like parrot said)
    - Blaise Pascal
  • #5
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    The rear calipers are different to the front calipers as regards to pushing the piston back in.
    On the rear calipers you need to turn thr piston clockwise to make it go in as it is on a threadlike shaft
    The way i do it is using some long nose pliers inbetween the two cutouts on the piston where one of the lugs off the pads locates and turn clockwise untill the piston in all the way in and flush again.
    Hope this helps
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
  • #6
    Senior Member kaibeecee's Avatar
    Pete
    yeah, ^^ he nailed it.
    I just made up a quick tool using 2 spaced pieces of 3mm plate, and TIGed it to the end of a 22mm 1/2" impact socket.
  • #7
    there is a tool that looks like a cube with different knobs n shit on it. you throw a 3/8 ratchet on it and u can turn back most pistons with that setup without too much effort or risk of slipping and butchering your hands
  • #8
    God I wish I would have noticed this thread earlier....... Sorry guys.
  • #9
    Junior Member S.K.'s Avatar
    Saku
    Vähäkyrö
    Western Finland
    FINLAND
    yeah mate make sure u dont try to force it back in with a g-clamp, i made that mistake with my first 86 (had to rebuild the seals). Jap specs are twist in....
  • #10
    Nov 2005
    sweet...
    done and done... i used wide mouth pliers and just turned them
    thanks for the help!
  • Similar Threads
    1. jdm 86 rear disc brakes
      By pogi in forum Technical - Questions
      Last Post: 29th October 2009, 08:36 PM
    2. FS: Corona Disc Rear Disc BRAKES!!
      By DR86FT in forum Car Parts For Sale
      Last Post: 2nd August 2009, 01:24 PM
    3. who sells rear brake pads for JDM disc brake
      By Rich_86 in forum Technical - Questions
      Last Post: 25th February 2008, 12:19 PM
    4. WTD Disc Brake Pads to suit AE86 JDM rear calipers
      By ke25 racer in forum Cars or Parts Wanted
      Last Post: 2nd April 2007, 09:42 PM
