Results 1 to 7 of 7
Thread: for all u people with sr conversions!!!
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    Default for all u people with sr conversions!!!
    have any of yous managed to get ur tacho working the guy that did my wiring said i cant wire it to the stock dash cause stock 86 motors run dizzy and sr20det runs cas. is there anyway to make it work or will i need an aftermarket tacho?
    Senior Member Roo.'s Avatar
    Andrew
    Gold Coast
    you probably have to mod the dash, i had to change a resistor in it when i went from dizzy to cas on my 4agze
    User fantapants's Avatar
    Pat
    mine has a little plug thing with mitsubishi tacho interface written on it. from a 20v with cas
    06/07/2011
    Nathan
    Gold Coast
    does anyone know who can wire it up for me
    Calvin
    Kilsyth
    yeh i want my ca working with factory taco me and sprinter86 tried to get it working using the same resistor setup as the 4agze but it never worked. at one stage it seemed like it was getting half a signal from only one plug.
    keen to find out if anyones works
    T18 in the build
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    get a pin out diagram from your ecu run a wire from tacho pin on ecu to your dash tacho black thick wire on the plug on the left side by mem but it may differ from e7 to 86
    the dyno pull to 300rwkw
    Dusty
    Lynbrook
    use the SR instrument cluster
  1. engine conversions what tail shafts are people using 1 peice or 2 peice
    By Celica RA45 in forum Technical - Questions
    Last Post: 21st February 2012, 09:20 AM
  2. CA/SR Conversions into AEs and KEs
    By bennyq in forum Technical - Questions
    Last Post: 20th July 2011, 05:38 PM
  3. workshops doing sr 20 conversions
    By aeadzy86 in forum General Topics (No Technical Questions)
    Last Post: 9th March 2010, 06:59 PM
  4. Replies: 3
    Last Post: 12th August 2007, 12:40 PM
