Results 1 to 5 of 5
Thread: Sway Bar Links
    Senior Member Simon-KE70's Avatar
    Simon
    Default Sway Bar Links
    just wondering, can a Z type bar be used on the front sway bar links to the LCA's instead of a straight rod? Mine are on a massive angle and has killed the bushes so just trying to get a solution to that problem that will work.
    Jonathan
    I think you should go to a blade adjustable front anti-roll bar. And use the holes that put the link in a more vertical position. Or you could posiably convert your current bar to a blade adjustable one, with some cutting and welding. The weld has to be strong of course.
    Mt Macedon
    Any chance of redrilling the mount holes in the LCA so the rod sits better?
  • #4
    Simon
    Jonny: welding spring steel completly roots the tension of the steel itself... even if it is the very end of the bar.
    Henny boy: hole is at the very edge of the LCA as it is.
    for the record... it is a S13 crossmember with cut and shut shorter s13 LCA's, holes drilled for the Castor rod and another hole drilled for the sway link, but even then, at ground height the link has a major angle on it... handling i cant notice anything terribly bad but it has thrashed out the brand new bushes al;ready in 2 track days.
  • #5
    Simon
    has anyone got a whiteline cataloge? i want to see if there is a product that would suit what i need.
  • Similar Threads
    1. Sway bar bushes
      By Moebius in forum Technical - Questions
      Last Post: 16th September 2008, 01:40 AM
    2. Sway bar D-links from S series diff
      By Hen is a total nutcase in forum Cars or Parts Wanted
      Last Post: 11th February 2008, 10:04 PM
    3. sway bar mounts
      By egg_83 in forum Car Parts For Sale
      Last Post: 31st January 2008, 04:03 PM
    4. font sway bar
      By 350hp4agte in forum Technical - Questions
      Last Post: 24th December 2007, 12:56 AM
    5. sway bar
      By jnr 13b in forum Technical - Questions
      Last Post: 7th October 2005, 03:43 PM
