Results 1 to 5 of 5
Thread: idle isue
    Default idle isue
    i was just wondering does anyone have any idea why my 4age wont idle under 2grand i have the idle switch wound right down even after the car warms up it still idles above 2
    thanks
    Veteran Nikkojoe's Avatar
    Tom
    Have you got cold start hooked up? It will be a vac leak somewhere in the intake path. Put your hand over the throttle body to block the air flow, if the engine stalls then its a leak in the throttle body region, if it still idles but much lower then its a leak somewhere in the intake manifold.
    Check to see the throttle is completely returning.
    Senior Member adam's Avatar
    Adam
    Auxiliary air valve on the throttle body. There's a wax in there which melts when motor warms up and closes the valve up for motor to idle normally (about 800rpms), coolant is supposed to run through it, but most people don't connect this up. When it's not connected up, the motor will idle at 2krpms+ when warm.
    I had the same issue and solved it by welding up the holes which this valve lets the air through in. A little trouble on cold mornings (need to keep foot on throttle) but apart from that, all good.
  • #4
    Tom
    Don't need to weld up holes, just get a sheet of thick gasket paper and insert between the cold start and tb. Much more reversible when you want cold start back
  • #5
    Adam
    I originally did that and it still idled at 2krpms so I just blocked up the holes.
  • Similar Threads
    1. Please someone help!!! (idle)
      By A.k. in forum Technical - Questions
      Last Post: 18th November 2010, 12:47 PM
    2. idle up and down
      By wntdae86 in forum Technical - Questions
      Last Post: 5th October 2010, 11:43 AM
    3. 4agze idle
      By Stej in forum Technical - Questions
      Last Post: 13th September 2009, 11:52 AM
    4. Help with carbs idle
      By doridori in forum Technical - Questions
      Last Post: 15th February 2008, 03:59 PM
    5. Idle @ 2,000rpm
      By Saikou in forum Technical - Questions
      Last Post: 10th January 2008, 09:38 PM
