^^^ boost cruising comment much?
a banana skin does work. if you just have a bog warmer do it. if you got an lsd or something thats half decent take it to a diff shop
does it only do it when it cruises at a steady speed??
if so just keep your foot flat and see how spongy the carpet is
1983 ae71
1984 ae71 with ke70 front
1983 ae86
ke ford laser with massive doof lol
i had a slight box whine i put worn gearbox/diff treatment, cant hear it now, but i mostly sued it because 2nd gear syncro is completely farked!
it would be worth a shot, i brought a tube of it, could buy a bit bigger thing of it and use it in box and diff. the more you put in the more effective it is i think.... also the thickest gear oil available helps, i run thicker oil in my motor to reduce noise/leaking.
