Results 1 to 5 of 5
Thread: Cams selection
    Member jy086's Avatar
    Nunawading
    Default Cams selection
    Hi guys...im going to put AE101 quads on my small port. with mild mods....what cams should i get? im thinking IN 272 EX264....i don't want lumpy idle....any suggestions thanks
    dan
    adelaide
    adelaide
    where do you want your power to be?
    Senior Member adam's Avatar
    Adam
    Knowing when you'd like max power will help in deciding what cam duration is best. Lower duration, max power in lower part of rev range, vice versa.
    A lot of people ask for maximum duration you can run on a standard ecu and most say it's at about 272 degrees, but with the standard ecu you don't rev it hard enough to reach the cam's full capacity. Keeping the standard rev limit and getting cams which suit it best would be around the 256 or 264 degrees max in my opinion.
    And with your unequal durations, from the research I've done I would personally go the longer duration on the exhaust side with your mods. Shorter duration on the intake, but with larger lift. Having the quad throttle bodies on the intake side, there won't be much restrictions compared to the exhaust and having a longer duration on the exhaust side will help rid the gases more efficiently (more time for gases to escape after combustion). *I don't know if that's right, I might've interpreted the information wrong.*
  • #4
    Jonathan
    After you buy cams, you still have a lot of choice in setup. As in the lobe center adjustment. This also effects the peak power vs lower torque and idle quality. So if you did buy some hot cams, and found your setup gave a lumpy idle, I think you could tune this out with adjustable cam gears. Lobe centers at about 110/110 should have a more factoy like idle. At 100/100 you are tuning more for top end max power, and you may have to bump the idle up. And you may have to change the ECU map on each setting, at least check your air/fuel ratios.
  • #5
    Nunawading
    oooh...thanks for all your info guys, i've got adj cam gears and also E-manage waiting to be installed...
  • Similar Threads
    1. Gear Ratio (Final) Selection?
      By assassin10000 in forum Technical - Questions
      Last Post: 15th August 2011, 10:24 PM
    2. DrawThrough turbo selection
      By pope in forum Technical - Questions
      Last Post: 29th July 2008, 12:30 PM
    3. boost handling and turbz selection
      By corolla_kid in forum Technical - Questions
      Last Post: 16th February 2007, 09:19 PM
    4. Initial D Fourth Stage D SELECTION 2
      By mc68 in forum Offtopic Discussions
      Last Post: 10th October 2005, 08:47 PM
