86 hand brake cables work. Well it did on mine t18 cables might be longer if thats what you used
mechanic did my t18 diff and shaft..
- pulled up hand brake, nothing at all.
- tightened cables, nothing
- change rear shoes and drums, still nothing,
:crazy:
are the cables at maxium stretch??
do i need to get new ones or just get the professionally shortend?
i think the way to solve this problem you have is to go to your local wrecker and get the front half of the handbrake cable from a SV11 camry, they r slightly shorter and make the t18 diff a bolt in affair in that aspect
i used t18 lines of the diff and put them straight into the lines near the middle of the tail shaft on my old 71 and i got awesome tension. just get them shortened
