Results 1 to 10 of 15
Thread: Epic Viabration!!! help
    Veteran Robo86's Avatar
    Rob
    Exclamation Epic Viabration!!! help
    Hey guys bit of an odd one.
    basically i have this MASSIVE vibration coming from the gearbox kinda area (bit hard to tell). It happens most on decel at about 2500rpm, but also does it on acel at simmilar revs. It has done it for a while now.
    have replaced the following parts;
    new flywheel
    clutch is fine
    new box
    new tailshaft (i thought this would fix it).
    now we are starting to think its the gearbox mount??
    any ideas would be sweet!!
    Robo.
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    dan
    adelaide
    adelaide
    tail shaft out of balance?
    Rob
    na i dont think so cause its EXACTLY the same after i swapped shafts, but maybe.
    my corolla
    3274 5374 - Roy
    dan
    adelaide
    adelaide
    are you running a 4 link? when i had a 4 link installed the angle on the tail shaft bearing was vibrating alot till i make the angle less agressive
    Seamus
    Milton
    standard links
    and car isn't nearly as low as it used to be (just thought id add that in)
    Aaron
    i would check engine and gearbox mounts first and then the exhaust.
    is the exhaust hanging of the gearbox and does it have a flexpipe? toyotas are bad for vibrations like this esp camrys. it almost always comes back to mounts
    even an engine mount can send this sort of vibration thru the drivetrain.
    Veteran slide86's Avatar
    Huw
    Hills
    id be looking at gearbox and engine mounts
    i bet all the ladies are getting you to drive them round now
    if its engine/gearbox mounts, just grab some cuscos...just got some myself...cheap from j-land
    Aaron
    yeah firmer engine mounts are nice but if you dont like vibration dont buy firmer mounts
    Senior Member riceburner's Avatar
    simple but possible, but i have a quick release handbrake 'drift' type thing and it makes a sh!tload of noise at times...
    Insert witty comment here....
  1. epic R/C drifting
    By AE092 in forum The Drift Channel
    Last Post: 20th September 2009, 08:57 PM
  2. Epic fail!!!!!
    By Mr Awsome in forum Offtopic Discussions
    Last Post: 3rd August 2009, 08:50 PM
  3. Epic
    Last Post: 15th July 2009, 02:44 AM
  4. epic driving...
    By fantapants in forum Offtopic Discussions
    Last Post: 9th April 2009, 08:17 PM
  5. Epic Movie
    By Grantobius in forum Offtopic Discussions
    Last Post: 29th January 2007, 06:45 PM
