Results 1 to 10 of 12
Thread: 20v crank timing gear
    Senior Member grantobius's Avatar
    grantobius
    nsw
    newy
    aus
    Default 20v crank timing gear
    l was just stripping my blacktop 20v and craked my cranl timing gear. l was wondering if 16v are the same???
    Any help would be much appreciated
    Nathan
    Lilydale
    yep the same as 16v mate.
    Jonathan
    Blacktop one is slightly different. The teeth are a different profile for a different belt.
    13521-16060
    Nathan
    Lilydale
    i was thinking of my silvertop one. mah bad!
    grantobius
    nsw
    newy
    aus
    Default 16
    well l will be running a 16v belt becasue l am doing a 7age conversion, would l be best of gettin a 16v gear
    South Island
    Timaru
    New Zealand
    The teeth profile make no difference, I have run ST and BT on a 16V belt,
    BUT, the TDC markings on the BT and the rest are different,
    so if you use a BT cam drive without the BT oil pump, your cam timing markings are out.
    The actual timing is the same,
    but the dot on the pulley on a BT drive is between two teeth, and on the rest it is right on a tooth.
    Quote Originally Posted by DX20VT View Post
    being that his doing a 20v 7age he'll have other timing issues to worry about aswell, so they wont make all that much difference
    South Island
    Timaru
    New Zealand
    Quote Originally Posted by Delazy View Post
    Well since I also used my one's on a 7AGE 20V, I can tell you that it does make the difference,
    between putting it all together and everything lining up perfect,
    and puting it together and the timing being a complete mystery.
    Jun 2009
    Grant
    California
    San Jose
    USA
    To get out of Grantobious' thread,
    It seems like I'm hearing that a 7age block with BT head, oil pump, tensioner, timing gear will actually line up the cam gears with a standard 16V timing belt?? Any need to modify the tensioner?
    Also, would the compression ratio become too high for pump gas if the BT pistons were used as well? I don't know where this conversion puts the pistons when at TDC but the extra stroke should increase compression ratio.
    Any thoughts? This is hella awesome if it really that simple. (Any ideas where I'm from?)
    Moderator Sam-Q's Avatar
    Endeavour Hills
    compression ratio will be a theoretical 12.1:1 which is ok with a good tune or else just go with the silvertop pistons
  1. Replies: 4
    Last Post: 15th March 2010, 07:48 AM
  2. WTB small port mani. Crank timing gear.
    By --Redwork-- in forum Cars or Parts Wanted
    Last Post: 6th March 2010, 10:00 PM
  3. WTD 20v timing belt crank pulley
    By 99Westy in forum Cars or Parts Wanted
    Last Post: 9th August 2009, 09:01 PM
  4. timing belt gear off the crank needed off a 4age
    By bradae86 in forum Cars or Parts Wanted
    Last Post: 25th June 2009, 10:44 PM
  5. 20V crank timing pulley, cant get off
    By ke70dave in forum Technical - Questions
    Last Post: 23rd December 2007, 06:46 PM
