Results 1 to 10 of 46
Thread: 15 x 10 superlites
    Nov 2006
    anyone ever fitted a set of 15 x 10 - 27 offset on their ke70 or 71 or 86? i've seen 15 x 10 challengers on the rear but what about the front? anyone have any pics of some good dish on a ke/ae?
    Nov 2006
    oops please delete mods wrong section .. to many tinnys <_<
    anz
    what tyres r u runnin with the 15x10s??
    Oldschool Member
    Mar 2007
    i dno why you would want to... they are 16x9 -15 on the front. so gaurds bigger than that gives you a good idea.
    Veteran Konakid's Avatar
    Henry
    Eastern
    <div class='quotetop'>QUOTE (andro0o @ Oct 28 2007, 01:30 AM) </div>My point.
    On such a light car where tyres like 215 - 235's just arent needed, wheels that wide for steering is overkill.
    Remember most nissan drivers use 9/9.5 wide steerers on silvias with 215 tyres and they weigh considerably more than corolla's.....
    Senior Member DavisJD's Avatar
    Im not disagreeing with you that wider tyres are bad KonaKid, but just because a heavier car is using a wider tyre, that isnt an argument against using it on a lighter car.
    Generally what stops people using a wider tyre for racing is class restrictions.
    Drift of course brings up a whole heap of new arguments and opinions.
    Oldschool Member
    Jul 2006
    Theres a whole lot more to it than simply asking "what width tyres?". You need to take a whole pile of variables into account.
    The responses on here indicate that whilst they fit, they may not be the best idea. That may well be true, however what exactly you plan on using it for, what tyres you intend to fit and how adjustable your suspension is needs to be taken into account at the bare minimum.
    Many responses have said outright that 2XX width tyres are too wide. As long as you can work the tyres enough so that they heat up, it dosen't matter. To that end, as long as you can get heat into them, the wider the better.
    If you ever intend on driving it in the rain, forget it. Get some cheesecutters or SLOW DOWN.
    Can you adjust your suspension to make the most of the extra grip afforded to you by the tyres? If not, don't bother. I just recently spent $4k on a set of double adjustable Koni's and Eibach springs to make the most of my tyres and handling.
    The weight of the car does come into it somewhat, but to say that you can only have a certain width for certain cars is not correct. I run 215/50R13's on my car, and it weighs 530kg (dry).
    Take the whole package into consideration before making a decision. Shelling out for better wheels now may make your car worth _something_ in a couple of years time.
    Leo
    Veteran biggo's Avatar
    Nick
    Noosa
    what size 13s? what tyre?
    me need some tyres for my 13s aswell
    Oldschool Member
    Jul 2006
    <div class='quotetop'>QUOTE (biggo @ Oct 31 2007, 02:07 PM) </div>I use Kumho V70A in a soft compound for supersprinting, and Yokohama A048R in Medium for the road. I dont think you can get A048's in soft, but if you can, I want them!
    Ok
    Seamus
    Milton
    someone got pictures of these suckers on a car? the 15 x 10 -26 (or whatever it is)
    ^ Clicky clicky!
  1. Replies: 0
    Last Post: 17th May 2010, 11:21 PM
  2. 15 x 10 superlites
    By SNAP in forum Technical - Questions
    Last Post: 1st November 2007, 11:57 AM
