<div class='quotetop'>QUOTE (flegburt @ Oct 28 2007, 07:40 PM) </div> :blink: so you read the article and is says they fit why are u asking us?
hay guys i was just reading some of the tech stuff an came across a part that
said u could use sw20 mr2 front insert in the front of a ke70 is true or false?
if they fit i take it they would act as a sort stroke?
the reson i ask is cause i got told that there is nothin that i could put in my
STD ke70 front as inserts to make it handle better!!
cheers steve
you can put them in ae86 struts, but im pretty sure ke70 struts are slightly smaller in diameter and thats why you cant get any shocks for them
Rust is a way of life
<div class='quotetop'>QUOTE (hachirusto @ Oct 28 2007, 10:09 PM) </div>and your correct... using ke70 struts is pointless... spend $200 bucks and get 86 struts and you will never look back.
