Results 1 to 7 of 7
Thread: Brake upgrades
    Senior Member eightsixboy's Avatar
    Paul
    East
    OK, i'm getting a conversion done soonish from hoppers stoppers and there kit uses massive twin piston au2 calipers, i am just thinking will they be TO big for an 86?
    Senior Member DavisJD's Avatar
    what size rotors are they using? (will they fit under you rim size 13",14",15",16")
    How far out are the calipers going to stick? (Bassically what offset rim will you need to clear them.)
    These are the questions you need to ask the people doing the work for you.
    If they fit, then no, its not to big, its never overkill with brakes, the bigger the better.
    Hope it works for you.
    The other problem may rise in the AE86 stub axles, which are fairly small, and may bend or break with excessive force.
    Paul
    East
    Well they told me its a whole kit, adr aproved. I have to have 15 icnh rims which i already have. No idea what rotors they use, they will be using a camry master cylinder.
    sounds like a goer then.
    No idea what these calipers are like. But its sounds like you may be on to a good thing. Let us know how you go and get some pics up once its done.
    Nov 2006
    ive had a quick measure and R32 gtst rotor n calipers will just fit under 15's just!!!!!!!
    fronts are 296 mm i think rears are 297 or something
    Veteran slide86's Avatar
    Huw
    Hills
    are you sure they arent 280mm?
    i have this setup and i fits easily in a 15inch wheel
    Nov 2006
    yeah sorry it was to late front are 280mm and rears are 297mm
    it would filll out the 15's though wouldn't it slide86? good to hear they fit and i can measure! :unsure:
  1. brake conversions/upgrades
    By sprinter666 in forum Technical - Questions
    Last Post: 21st March 2012, 08:35 PM
  2. Brake upgrades.
    By --Redwork-- in forum Technical - Questions
    Last Post: 9th February 2009, 02:03 AM
  3. what brake upgrades do people do???
    By cjplow in forum Technical - Questions
    Last Post: 23rd June 2008, 07:29 PM
  4. brake upgrades
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 27th February 2008, 03:15 PM
  5. Brake Upgrades.
    By wideslider in forum Technical - Questions
    Last Post: 5th May 2006, 12:51 AM
