Results 1 to 10 of 13
Thread: Wide steelies?
    Default Wide steelies?
    Hey all,
    Chasing some wider wheels to use as skidders, but not really keen on spending coin from japan at the moment.
    So, my question is, is there anything out there, be it toyota, mitsi, nissan, in a stock steel wheel, that is wider than a 6 inch, in a 14 or 15 inch diameter?
    Not too fussed about offset, bolt on spacers can sort that, just chasing something as wide as possible.
    Even if they need to be widened.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    There's a company up here (brisbane) that sells just the outer bands... (Race engineering)
    Can get 8 or 10 inch wide in a 15. Think the widest you can get in a 14 is 8.
    Just gota find some wheels with the right sized ceters to remove and weld into the new bands...
    Either way they buy the bands off of ROH so you should be able to get them anywhere really..
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    just use stockies. they light up easy and you can get tires cheaply.
    if you want cheap but also have performance in mind get some 15x8 challengers. theyre cheap and 15's have they biggest range of tyres available for our little cars
    Veteran Konakid's Avatar
    Henry
    Eastern
    15x8 superlights or challengers are damn cheap for their size/offset (500pr about)
    look 10x better than stockies too haha
    Senior Member doony's Avatar
    Dan
    13x10 and 13x8
    Or driving in a wolf pack.
    todd
    they aint steelies doonasaur.
    they be rx racing wheels from memory of beaus thread. he will confirm.
    i want to get a set of these 4 my 86 tuff as farrk http://www.diamondracingwheels.com/prochallenger.html
    Veteran 45KIDS's Avatar
    Brodie
    Toowoomba
    Quote Originally Posted by widebody86 View Post
    15x18's yepppp gunna look good on my ke hahaha
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    family friends races sprintscars here and states, was looking through his ordering catalogue and asked him about them as they were soooo cheap, he basically explained that after couple of bumps on the road they be ruined.
    The reason they work on sprintcars is that they dont have all that much air pressure in the tyres and the the huge sidewall helps impacts aswell, also the tyres they use have no thick rubber/steel belts/sideswalls/tread like road tyres so they basically collapse on themselves when not on a rim
    Dave
    R31 wheels are 15x7 i belive, steel things. cheap from wreckers
  1. MELB: Used Steelies
    By malk234 in forum Cars or Parts Wanted
    Last Post: 15th January 2012, 03:24 PM
  2. 14x8-22 steelies
    By Jacobxxx in forum Car Parts For Sale
    Last Post: 23rd March 2011, 03:02 PM
  3. who makes steelies
    By widebody86 in forum Technical - Questions
    Last Post: 16th August 2009, 03:08 PM
  4. 13inch steelies
    By RoLLa project in forum Car Parts For Sale
    Last Post: 4th October 2007, 01:58 PM
