Page 1 of 21 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 206
Thread: What do you use to initiate?
    Senior Member Intense's Avatar
    Aaron
    Default What do you use to initiate?
    I was talking to my mate about what method he uses to start a drift. He used to use handbrake only but now his new car has a handbrake set up that won't lock the wheels properly which got me to thinking, just what is he going to do now?
    Anyway as for me, I prefer feint drift for 2 reasons. The first is that it's very kind and forgiving on the drive train so no nasty blown t50's or t series. And secondly it's a really easy and simple way of getting the car to kick out. It's gradual so it gives you a lot of time to react and you can use it under pretty much every situation. Just turn away from the corner, turn in and mash it, works every time for me.
    Never really had a car that had an effective handbrake to practice with so that's another reason I prefer this method. But what do you guys prefer?
    Veteran Konakid's Avatar
    Henry
    Eastern
    comp lock is sexual when you get it right.
    Member yakusikimo's Avatar
    Mat
    scando flick then compression lock is pretty much the only way to get a stock ke70 side ways in the dry i think. high revs in 3rd flick the car then change down 2nd release the clutch at max sidewards G then u will slide and lose heaps of speed. u cant power out cos 4k is shit so its not really drifting.
    Member daily_driven_death_sled's Avatar
    Gold Coast
    i turn on my hazards downshift and mash the gas, in the wet
    i usually inerta it in the dry, same as the OP
    Calvin
    Kilsyth
    Intense: can u describe feint?
    I use shift lock handbrake and clutch. All depends on the corner, wet or dry and how much power car has
    Shift lock is most fun in stock motor Ke's tho
    T18 in the build
    Veteran ae71neo's Avatar
    Travis
    Blue Mountains
    Depends on corner. Clutch kick, or feint, clutch kick, handbrake. Or just foot brake.
    Aaron
    Quote Originally Posted by Hokey View Post
    For a right hand corner, I'll come up from the outside edge but not all the way over, before the corner starts flick it left so the suspension binds up on the right hand side, then turn in and once the suspension has bound up on the left mash the loud pedal. This should kick the back out nice and slowly rather than kicking it out violently so it's really easy to catch. If you want it to kick out quicker just use a more aggressive turn in or clutch it on the turn in. You need good front end grip to do this but if you find yourself understeering you can go into the corner hot and get on the brakes to help load up the front a bit and get a bit more grip that way. It's really the only way I know how to get a car sideways pre apex into a corner.
    I really need to learn how to use the handbrake and maybe proper clutch kicks too.
    Veteran Dom86's Avatar
    Dom
    Balga
    Feint/scando flick, power on power off.
    I hardly ever use the hand brake or clutch, just usually to correct the drift.
    I've found that people in bigger cars use the hand brake more....
    The Track Car Build: Indigo
    A Heap Of For Sale: The Heap
    Kieran
    Kick the clutch or if there's power, power over = win
    Senior Member doony's Avatar
    Dan
    i thought this thread was initiating sexual activities with the opposite sex.
    i am now truely disapointed.
    Or driving in a wolf pack.
