Results 1 to 8 of 8
Thread: Fuel problem?
    Senior Member KE70's Avatar
    Alek
    Lalor
    Default Fuel problem?
    My car is still not running properly but I have finally pinned it to a fuel problem.
    The car runs but very crappy when you try to rev it and you can't stab the throttle, need to gently increase it otherwise it pops and splutters. With spraying start your bastard down the throttle body it works fine and revs cleanly.
    Fuel pump seems to be fine as there is ~45 psi in the fuel line when the car is running. Also the injectors were cleaned and tested professionally.
    When I rip out a spark plug there is a little bit of fuel in there, im not sure what could be causing that.
    Any help/advise would be appreciated.
    Trev
    Queensland
    Redbank Plains
    Before you diagnose the fuel system have a look at the TPS adjustment.
    Alek
    Lalor
    TPS seems to be fine, I changed it and set the values again. There were not spot on to factory specs but they are the closest I could get.
    stefan
    vic
    eastern suburbs
    45psi seems to be too high, should be more like 25psi on standard fuel pressure reg. then again when i had a malpassi reg 18psi made the engine run super rich
    Alek
    Lalor
    The gauge we had was made for air so it could be wrong, lol
    But there is defiantly pressure there so that rules out the pump.
    Dusty
    Lynbrook
    what sort of computer are you running on the car?
    Trev
    Queensland
    Redbank Plains
    Quote Originally Posted by KE70 View Post
    Ok, Closest isn't always operational tho, Nelsons sprinter developed the same problem after a night on the skid pan, Turned out to be the TPS.
    Alek
    Lalor
    Yeah ill check the TPS again and let you know how it goes.
  1. fuel problem
    By Shitbox in forum Technical - Questions
    Last Post: 8th June 2012, 06:28 PM
  2. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  3. Idle and fuel problem, running rich
    By capatown in forum Technical - Questions
    Last Post: 6th December 2010, 10:36 PM
  4. fuel rail adaptor plate for aftermarket fuel pressure reg
    By 1sik20valve in forum Cars or Parts Wanted
    Last Post: 5th January 2010, 02:18 PM
  5. Fuel Overflow Problem - Any Suggestion???
    By joshcris in forum Technical - Questions
    Last Post: 30th March 2008, 04:00 PM
