Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: 13b/13bT powered 86's?
    any write up's or links on this build?
    apparently there's one in Sout Aus same colour as mine going around?
    and that raceflow one 2 (too expensive) :unsure:
    i am thinking about going a 13bt in my 86 as parts are a dime a dosen
    thanx
    -Jarryd
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    yeah there was a blue 1 that was built up a couple of years ago. i think the guy worked at emtech or had some close affiliation with em, mayb worth calling them for info
    ok
    so no ones found a link?
    i mite have 2 give them a buzz when i suss em out
    Mar 2010
    i know its a bit of a prick tease but if ya go on youtube there is a 20b turbo 86!
    the way it pulls away is totally nuts.
    but sorry, no info on people actually doing it here.
    do it, do it, do it.
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    a simle search would have found some info
    hope u got alot money for this u gonna need many custom parts
    good luck
    Mar 2006
    if your trying to do this convertion in NSW forget it.
    nah was goin 2 do it in sa
    why dont bother in NSW
    fron cut series 4 rx7 should be $2,500
    then that includes a fron break upgrade and usually a series 4 gearbox. tough as nails.
    custom tailshaft would be a head fuck but welding up mounts to the original X member isnt that hard
    rotors have 2 mounts compaired to the conventional piston engine which usually consist of 4
    Senior Member Dongaz's Avatar
    Cameron
    The Gap, Brisbane
    I cant remember if I read that if you use the rx7 gearbox it would be a bit big for the tunnel so a bit of modding would be in need there. Or you could use the w58 box. I know alot of 13bt's use that box as it is damn strong and there is a custom b/housing for them already made up, the same as the 4a to W series box. I cant remember atm but I have seen a major rotory shop selling them. It was up on the net aswell. Ill see if I can find it again and ill post it up later. I was going to go 13bt aswell but a 4agte package came up that was too good. Which is alot less than the 13bt but then again it wont be anything like a rotor. Ill get one done one day. Goodluck
    Cameron
    The Gap, Brisbane
    Here we go I guess the adaptor plates are atleast cheaper than if you were going to use the 4A - W series.
    Atleast you know that the W series is strong if they are using them behind the 13bt's in drag cars and such with a lot of power. Confidence for me that it should hold a good 300hp.
    Cameron
    The Gap, Brisbane
    Lol didn't even look at the other thread again. I now see someone already stated about the plates and the box.
  1. Thoughts on a 13b 86
    By Fallen Angel in forum General Topics (No Technical Questions)
    Last Post: 7th November 2011, 02:30 PM
  2. my 13b powered hachi
    By cmesld in forum AE86 Owners Forums
    Last Post: 29th September 2008, 10:40 PM
  3. MAT713's AE86 now 13B TURBO
    By Klutch in forum AE86 Owners Forums
    Last Post: 26th April 2008, 02:26 PM
  4. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
  5. Buyin JNR 13B's 20 valve
    By jwvdg in forum General Topics (No Technical Questions)
    Last Post: 27th March 2006, 09:28 PM
