Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Heater Tap...Where do the hoses go?
    Hugh
    Default Heater Tap...Where do the hoses go?
    Hey guys, doing my GZE conversion, and thought might change my heater tap, as it is fucked, and no engine made it all the more simpler...however, I pulled it out without noticing where the hoses went...so...where do they go to??
    stefan
    vic
    eastern suburbs
    theres a maximum of 4 ways it can go on. im trying to figure out what way it goes, though fwd engines plumbing systems suck dick in an ae86
    so just give it at go and see which works best.
    i do beleive however nothing will work 100% correctly unless you have a rwd ae86 plumbing setup
    Dave
    Quote Originally Posted by yoshimitsu9 View Post
    your not trying to sell rwd ae86 plumbing setups are you?
    fwd thing works perfectly well
    will this help you out??
    the other pipe that comes out of your heater goes to the back of your head.
    ive got that setup, works perfectly fine.
    stefan
    vic
    eastern suburbs
    i run fwd setup in mine and stated my heater sucks. i must say i bought my car with a very questionable setup. in my car the water out let on the head doesnt even have an extra pipe coming off it!
    to the wreckers i go
    Dave
    hey??
    there is only one pipe coming off the back of the head.
    the pipe labeled "loose section of pipe bla bla bla" goes to one of your heater pipes (via the valve). and the plug on the back of your head goes to the other pipe of your heater core.
    well thats how mine is done anyway....im pretty sure....
    my heater used to work well, but my valve is stuffed (16V in my car btw) another one of my jobs....
    Veteran Nikkojoe's Avatar
    Tom
    Quote Originally Posted by ke70dave View Post
    hey??
    It's the other way around, back of head pipe goes to heater tap/valve, pipe from remote thermostat goes to other pipe on heater core
    Dave
    yer sorry Nikkojoe is right
    valve is there to stop the hot water (from the head) from goin into the heater.
    though i reckon it woudlnt matter if you got them the wrong way around. assuming there isnt some one-way valve inside or something....
    Hugh
    Im confused...I'm talking about the two pipes from the valve, connected to the cable going inside to the heater (i thought the valve was the heater tap)
    There are two pipes coming out of, i assume, the heater on the firewall, and two pipes out of the cable controlled valve and one coming out of the back of the head. Currently, the remote thermostat pipe labeled "Loose section of pipe used as an extension piece" is going to the back of the head..
    Is this wrong??
    Moderator Sam-Q's Avatar
    Endeavour Hills
    ok it goes like this:
    back of head to heater tap,
    heater tap to heater core
    heater core to back of water pump or thermostat housing
    Hugh
    thanks Sam...I assume the heater core is the two pipes coming out of my firewall...does it make a difference which pipe it goes in and which it goes out??
  1. Where to buy AE86 RWD heater hoses and thermo & heater gaskets
    By oz_eight6 in forum Technical - Questions
    Last Post: 22nd October 2012, 11:42 PM
  2. AE86 Heater Tap
    By hayashi in forum Cars or Parts Wanted
    Last Post: 21st January 2012, 10:13 PM
  3. ke70 heater tap
    By kronix in forum Cars or Parts Wanted
    Last Post: 6th November 2009, 07:15 PM
  4. WTB:[VIC] - AE71 heater core & Heater tap..
    By tc-rolla in forum Cars or Parts Wanted
    Last Post: 16th August 2009, 02:08 AM
  5. WTB: AE71 Heater Tap
    By hugh in forum Cars or Parts Wanted
    Last Post: 17th February 2009, 01:14 PM
