Results 1 to 4 of 4
Thread: 4ac ignition coil wiring
    Tigh
    Vic
    Southside
    Default 4ac ignition coil wiring
    As title.. I replaced the engine bay loom as the old one was chopped & think I may have it wrong. Anyone have a pic?
    So 2 wires from bay loom to +ve & -ve to corresponding bolts on ignition coil..
    Where does the wire from the distributor go? -ve on ignition coil?
    Then there's one short wire from the rectangular plastic bit on top of the coil. that links the -ve to -ve on the coil?
    Help will be really appreciated
    Veteran slide86's Avatar
    Huw
    Hills
    dizzy goes to the -ve side of coil
    make sure the -ve side of the coil doesnt GROUND anywhere otherwise the car wont start
    Nathan
    Lilydale
    the thick black and orange wire from the car loom goes to one side of the coil resistor(the big white block on top of the coil), and the other side of the resistor goes to the coil positive.
    And as already mentioned, the wire from the dizzy goes to the coil neg, aswell as a thin black wire from the car loom whick is the tacho signal wire.
    hope this helps dude!
    Tigh
    Vic
    Southside
    Quote Originally Posted by biGtai View Post
    Then there's one short wire from the rectangular plastic bit on top of the coil. that links the -ve on the little box to -ve on the coil?
    & this one?
    What does do/link?
    Ignore meee.. Cheers hopefully should be able tofire up now
    Last edited by biGtai; 16th April 2009 at 03:07 AM. Reason: didnt read previous response
  1. 4ac dizzy/coil wiring help
    By rthy in forum Technical - Questions
    Last Post: 6th February 2010, 12:33 AM
  2. Need Ignition coil
    By Drew in forum Cars or Parts Wanted
    Last Post: 11th November 2009, 08:51 PM
  3. smallport ignition coil
    By xero in forum Cars or Parts Wanted
    Last Post: 5th March 2009, 08:02 AM
  4. 86 ignition coil
    By sundee in forum Technical - Questions
    Last Post: 28th December 2008, 02:08 PM
  5. Fitting Aftermarket Ignition Coil
    By DRFT - 86 in forum Technical - Questions
    Last Post: 2nd July 2007, 03:33 PM
