Results 1 to 10 of 14
Thread: Usable XT130 pars for AE71?
    Default Usable XT130 pars for AE71?
    hey everyone,
    I'm a bit of a newbie with toyota's so i need your help with one question.
    What usable suspension and steering parts can you use from a XT130 corona?
    I have a AE71 and want to stiffen up the front. What setup is recommended?
    I currently have TRD 8kg springs to fit 86 struts. Can i use XT130 struts with TRD springs, xt130 lca's and steering arms? Whats bits n peices will fit or wat combination is required to fit into the front of my car? Also, what shocks?
    Pat
    Can i use XT130 struts and sigma lca's? Do i need longer tie rods?
    The only reason i want to mix xt130 and sigma parts is because they're easily available where i live as no lazy k#nt on here wants to send parts lol.
    Just wanting to know the cheapest setup
    Senior Member shinny's Avatar
    Liam
    the xt130 LCA's give you about -1.5 camber
    the sigma arms are a little longer so more negative camber
    as for using the struts i'm not sure maybe try a search
  • #4
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    yeah you can use the struts. they are the same diam as 86 gear. brakes are a little better? aswell over 86 stuff.
    FTP.
  • #5
    Reeece
    Casula
    u wont be able to use the springs on the xt130 perches.. There different, either run coilovers on the struts/weld on ae86 perch or BUY my xt130 king low springs
  • #6
    dan
    adelaide
    adelaide
    if you use gh sigma arms and xt130 struts and ra 40 celica rack tubes you will have approx -2.5 camber the xt130 struts have less camber than 86 ones
  • #7
    Senior Member resol's Avatar
    steve
    vic
    Quote Originally Posted by cracker View Post
    actually sigma arms are more like 4 degrees....
    gunner:
    ALL DRIFT MODIFICATIONS
  • #8
    Veteran shift_rook's Avatar
    SE Burbs
    xy130's are twin piston calipers nom nom nom
  • #9
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by DrifTE72 View Post
    Not all.
    Early XT130's are Single piston Girlock calipers (quadlight front)
    Late XT130's are Twin piston Sumitumo calipers (twinlight front)
    RT132 / RT133 are all Twin piston Sumitumo calipers (quadlight or twinlight)
  • #10
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    XT130 struts with girlock calipers do not fit on AE71 steering arms.
    2mm centre distance difference
  • Page 1 of 2 1 2 LastLast
    1. Xt130 struts into ae71??
      By Gabe in forum Technical - Questions
      Last Post: 11th July 2011, 09:43 AM
    2. XT130 Coilovers, suit KE70/AE71 TAS
      By Prewer in forum Car Parts For Sale
      Last Post: 2nd August 2010, 10:32 PM
    3. KE70/AE71/AE86/XT130 bits
      By sr_rolla in forum Car Parts For Sale
      Last Post: 8th February 2010, 09:44 PM
    4. ae71 pedal box, xt130 suspension
      By roughworld in forum Car Parts For Sale
      Last Post: 21st January 2010, 08:35 PM
    5. Are these brake pads usable?
      By v-tec in forum Technical - Questions
      Last Post: 3rd January 2007, 12:14 PM
