Results 1 to 8 of 8
Thread: Engine troubles
    Member Bart's Avatar
    Bart
    Geelong
    Default Engine troubles
    Hey guys,
    Just a quick question. I was changing spark plugs tonight and noticed oil on plugs one and two. Does anyone know what could cause this? Then engine has been running quite shitty of late. It was blowing abit of smoke with the oil that i was told to run. Swapped it to something abit thicker and thought it solved the problem but maybe not. Is there something that i should check or should i just save for a new motor?
    Cheers Bart
    Veteran Rice86's Avatar
    Richard
    Liverpool
    im going to take a wild guess and say piston rings are on its way out?..
    start saving for a rebuild or something and just drive it as normal...i wouldnt be reving it past 5000 until u know whats wrong with it incase u do more damage
    dose
    john
    nsw
    liverpool
    what colour is the smoke .. think its blue means piston ring. and yes oil that is light weight like eg 10w-50 is way to light for an old motor and can stuff it up..
    start saving for a re-build or new motor.
    Senior Member adam's Avatar
    Adam
    Oil down the spark plug valleys could also be from old worn out cam cover seals.
    Blowing smoke could also be from old valve stem seals. If it there's grey/blue smoke while you're on the throttle, most likely rings, but if it smokes while engine braking down a hill for example, chances are it's the valve stem seals.
    Senior Member Simon-KE70's Avatar
    Simon
    if you roll down a hill and put it in a lowish gear say 3rd down big hill at around 100 kph and drive for 10 seconds off the throttle, then you just slam the throttle and blue smoke pours out the back... thats your oil rings worn out.
    Site Supporter Javal's Avatar
    Josho
    Before you shell out on a new motor, do this -
    Borrow a compression tester from one of your mates (or just get a workshop to do it)
    Take base compression reading
    Pour 20-50ml oil down one spark plug hole
    Compression test that cyl
    Repeat for the other 3 cyls
    Compare against base values
    If the pressure reading go up compared to the base readings, then your rings are on the way out.
    If they stay the same, then the problem will 99% of the time lie with the valves (i.e. valves sticking, burnt etc)
    Bart
    Geelong
    It blows abit of smoke when im up past 4500rpm but nothing under that. It pulls great under that then its pretty shit after that and up to redline. Nothing like it used to run when i first got it. I think i will have my mechanic mate have a look over it. Would rather put my krudd coin towards some nice offset wheel!!
    Bart
    Josho
    Quote Originally Posted by Bart View Post
    Bart
    Possible TVIS problem then?
  1. Gearbox troubles
    By MattAE71 in forum Technical - Questions
    Last Post: 5th August 2010, 08:01 PM
  2. gearbox troubles
    By rolla92 in forum Technical - Questions
    Last Post: 16th May 2009, 02:06 PM
  3. Car troubles...
    By hugh in forum Technical - Questions
    Last Post: 19th November 2007, 10:35 AM
  4. wiring troubles
    By cmesld in forum Technical - Questions
    Last Post: 14th April 2007, 07:59 AM
  5. engine troubles
    By blu 86 in forum Technical - Questions
    Last Post: 21st September 2006, 07:23 PM
