<div class='quotetop'>QUOTE (Maxhag @ Dec 12 2007, 11:17 PM) </div>AE82 twin cam fuel injection pump is good for it.
Hey guys,
I want to put a surge tank in my GTE, and i was just wondering what Lifter pumps people use or recomend?
I will be using a 2L surge tank with a VL turbo Bosch pump. All i need is the lifter pump......
thanks
J Riftin
i used an in tank vl turbo one too. with a bosch 910 external.
i just modified the original pickup (aussie tank) and bolted in the vl lifter pump. it has been going strong for almost 2 years now!!
<div class='quotetop'>QUOTE (TopSecret @ Dec 13 2007, 09:16 PM) </div>AE82 twin cam fuel injection pump is good for it.
[/b][/quote]
sorry to hijack but does it matter what motor ae82 ie 4age, 4afe aslong as its one of the fuel injected models the pumps should be the same
i was actually planning on both pumps being external......
I didn't think i needed to have it intank.. Cant both pumps be external?
thanks
J Riftin
mine are, i have a facet 4 psi feedin the surge with a bosch as my pressure
yeah any low pressur pump will be fine man, thats what i use
cool
thanks guys
i used to have an external lift pump, found it to noisy. is the facet on quiet? i think i had a carter external lift pump.
