Results 1 to 10 of 13
Thread: 2jz-ge??
    Senior Member ThatsHowWeRoll's Avatar
    Dean
    Ballina
    Default 2jz-ge??
    Hi guys,
    Starting to plan my next project which is gonna be an MX83 cressida. jap vip style.
    Have been thinking about the motor side and want to do something different and wanna go natro power. Straight six with exhaust, intake, cams maybe. engine bay wiring hiden...
    Anyone have experience with the natro 2jz-ge?? Are they still a worthy motor natro?? Would it be that much better than 7mge??
    And what manual boxes can you fit to them??
    Cheers,
    Deano
    John 1:12
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    how much u planning to spend ? theres a guy down in vic selling a 1jz mx83 for 7k if u feel that will save u time and money
    Dean
    Ballina
    i want to start with a stock standard car this time and make it to my tastes.....i want to build it myself this time.
    Not to worried about cost...i would spend up to 5g on an engine swap and a bit more on for the GB. Just want to know if the jz is worth the swap over the 7m?
    John 1:12
    Mt Macedon
    I like 2JZs alot more than 7Ms, but then again it involves a lot of work to fit one to an MX83 when there is already a 7M in there. With that money and time you could get the 7M strong and reliable.
    Also bear in mind that it costs quite a bit to get a manual gearbox behind a JZ engine. You can make W58, R154 og V160 fit with varying difficulty and expense.
    So while I like the idea, I'm not sure it'd ever be worth it. Though you'll have to decide that for yourself.
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    go w58 man, eaaasy as to make a bellhousing to fit it, i have a few w bellhousings laying around that u can get cut n shut
    or w55s are worth like 330 from a wrecker, pm me if yu wanna know where, i know where theres a few
    MY JZX83 (clicky)
    Mt Macedon
    There's also a factory JZ-> W58 bellhousing (from NA JZA80) but they are hard to find, or around $400 new genuine.
    Dean
    Ballina
    cheers for the info fellas....have given me something to think about.
    sounds like the GB will be the most stuffing around...is it the same deal if i stuck with the 7mge with the GB choices?
    cool beans.
    John 1:12
    Veteran Konakid's Avatar
    Henry
    Eastern
    Motorfix did a build up of one in an GX73 for a customer. check the build thread here to find out what you need, should be fairly similar?
    http://translate.google.com/translat...3Doff%26sa%3DG
    Veteran slydar's Avatar
    Dimitri
    you will also need a sump swap. all na 2js are mid sump, and you need a front sump.
    having said that. na 2js are awesome. na jza80s are actually pretty fast, 14sec 1/4s fast.
    i would go 2j. think is like, even manual bellhousings/flywheel ect for 7ms arent actually cheap/easy to get really so you will be spending money there regardless.
    78's
    Senior Member patience's Avatar
    Iain
    Alderley
    Cams are hard to find for a NA 2jz from what I remember when I was a supra owner, there were alot of NA guys wanting to do built motors but the massive lack of aftermarket cams was stopping this so they just sold up and bought 2jzgtes.
    This may have changed in the 2.5 years since I owned one, but the only ones I remember were custom items for a group buy and they were big dollars.
    There were alot of pus extractors floating around too so be careful.
    As slydar said, there were a few boys doing high 14s in their NAs. Just get a 1jz tbh though, unless you are really set on atmo and want to be different.
  1. 2JZ CRESSIDA [QLD]
    By J0RD0 in forum Cars for Sale (Toyota Only)
    Last Post: 28th February 2012, 11:44 AM
  2. 2jz corona wagon
    By ecko in forum Cars for Sale (Toyota Only)
    Last Post: 31st October 2011, 12:09 AM
  3. 2JZ AE86
    By Nicko in forum Youtube Chan
    Last Post: 20th September 2011, 03:52 PM
  4. 2JZ-GTE pistons x 4
    By chang_hb in forum Car Parts For Sale
    Last Post: 27th March 2010, 12:33 PM
  5. WTB= 2JZ-GE Enginge, Gearbox, Loom etc!!
    By Dale91 in forum Cars or Parts Wanted
    Last Post: 22nd July 2009, 12:26 PM
