4gz!
you can by an already built running setup for that. how much power you want? just wanna use stock stuff?
cheap easy rebuild - piston rings, upper and lower bearings, gaskets
cheapish tough streetable motor - id also get some toda 260 cams, larger jets for your carbies, head port and polish, toda valves and valve springs
