Results 1 to 3 of 3
Thread: 4AC valve clearance
    Default 4AC valve clearance
    hi all, i want to shut my noisy tappets up but dont know the sequance i have to adjust the valvs in. i know the clearance is intake- .008' exhaust- .012' but i dont know in what order the valves need to be done. i know the firing order is 1-3-4-2 so when number 1 piston is at TDC what number valves do i adjust and and so forth.
    would really appreciate the help.
    Senior Member Dylan's Avatar
    Dylan
    Hi this should help you out
    Thanks man. that is what i need.
  • Similar Threads
    1. 3tc valve clearance
      By eli5 in forum Technical - Questions
      Last Post: 9th January 2013, 02:14 AM
    2. 20 valve cams, valve springs, (and the third lobe touching...)
      By Jonny Rochester in forum Technical - Articles
      Last Post: 30th August 2010, 12:02 AM
    3. 4ac valve clearances wanted
      By Adsport in forum Technical - Questions
      Last Post: 19th February 2009, 12:05 AM
    4. 4ac valve clearence specs??
      By TOY3TG in forum Technical - Questions
      Last Post: 17th February 2009, 08:43 PM
    5. URGENT, need valve clearance settings for 20v silvertop
      By dr1ft-pig in forum Technical - Questions
      Last Post: 17th May 2008, 11:55 AM
