Results 1 to 10 of 15
Thread: 4agze+T50
    Senior Member Stej's Avatar
    Steve
    Default 4agze+T50
    hey i have a 4agze with an sc14 charger on it with a jdm t50 box iam just a bit concerned that the gearbox wont hold up the gearbox at the moment seems all fine just wondering if anyone else is still using a t50 with either a gze or turbo setup and if they have had any issues?
    i use the car as a daily and hoping to get a few track days with it nothing serious
    Site Supporter Javal's Avatar
    Josho
    Most people running 4AGZEs are still using the T50 gearbox. Operating it with mechanical sympathy will prolong its' life, however you should consider that it is having more torque fed through it then it was ever designed to handle.
    Failure is inevitable, but treat it nice and you should get a good life from it. You'll know when its' on the way out. Shifts will get crunchier (especially 2nd to 3rd and 3rd to 2nd) and whines will get louder. 2nd gear is usually the one which goes. When this starts, i recommend you start obtaining the parts for a W5x gearbox conversion, especially if you are considering upgrading to a 4AGTE.
    Also please use punctuation in your posts, there isn't a single full stop in there.
    Steve
    hehe sorry.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    itll be right mate. keep power below 200hp and just double clutc h+ rev match and youll never have any issues.
    you can break a t50 with a 4ac is you dont know how to shift.
    Josho
    Quote Originally Posted by riojin View Post
    Werd.
    Like i said, mechanical sympathy.
    Steve
    yer i have not got the motor dynoed in the ae86, but i had the motor in an ae92 which made 160hp atw so should be making a little bit less witht he 86. I do try to take it very easy on the gears. Just wanted to know if it is really nessassery to go W5x box
    Dusty
    Lynbrook
    I am running an sc12 with a nevo pulley and T-50, I usually buy a few and keep them as spares, but I have never really literally blown one, jsut the synchro's start to wear out a fair bit and get harder and harder to select gears.
    So keep a few spare and you will be right
    Veteran Konakid's Avatar
    Henry
    Eastern
    Use an organic H/D clutch it will make it last ALOT longer than a button clutch or other aggressive clutch.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    mine lasted in my streeter with a heavy ceramic cluctch for ages 130kw never made a sound then one day during a very conservative gear change detonated lol. It will die but may last for a long time, if you want to be confident do a w5 convo
    AE86 THE BEST
    Mt Macedon
    Also losing the synchros in a box is no sign that it is going to break. I used a synchroless T50 (and 11psi 4AGZE) for over a year before it gave up.
  1. KE35 Corolla hardtop (2dr) + 4AGZE + T50 + T series diff
    By ke35 in forum Cars for Sale (Toyota Only)
    Last Post: 8th February 2011, 05:18 PM
  2. (qld) t50 gear box,cluch,tail shaft, 4agze computer & loom
    By 4agzezook in forum Cars or Parts Wanted
    Last Post: 23rd July 2010, 09:06 AM
  3. rwd 4agze+t50+extras $500
    By ToySprinta in forum Car Parts For Sale
    Last Post: 19th January 2009, 11:29 AM
  4. stock ae92 4agze flywheel in t50
    Last Post: 23rd May 2008, 06:53 PM
  5. gze flywheel and clutch setup onto a 4agze (t50)
    By tom__86 in forum Technical - Questions
    Last Post: 25th September 2005, 03:04 AM
