Results 1 to 10 of 15
Thread: RIM Issue
    Default RIM Issue
    Went to the local tire shop today to have my tire check as the tyre has been losing its pressure. The store has mentioned that the reason is due to the rim (15x8 -15, no buckle or damage) is too old and too much offset thus it does not hold the pressure of the tire anymore.
    Has anyone experienced the same issue and where can I get the rim repaired or what is the issue??
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Is it a 2 or three peice rim...
    The join could just need to be resealed with silicon if its a multi peive rim....
    If the wheel is straight with no damage it sould hold air..
    Offset has NO bearing on it at all...
    Of its a single peice rim then. either the tyre is damaged or the vavle is stuffed.
    Member cable tie's Avatar
    shaun
    nsw
    avalon
    pics of rims.... i'm in the market for some 15x8-15's if u wana sell them
    second to a hammer a cable tie can fix anything!!!!
  • #4
    its a work equip 3pc rim and the store has tried to put some stuff (some beards thingy) to strength the joint between the rim and tire, but pressure still leak along the wall. valve has been changed too. btw, its a brand new tire.
    where can I buy metal valve???
  • #5
    shaun
    nsw
    avalon
    where u located???
    new tyre?? what size??
    how old the rims>>?? u used them b 4>?? maybe the edge is slightly rollled out if there used?? or if u had them repaired there may be a slight blemish u can't seen on the in side of the rim where air is leaking out???
    if the rim needs fixed talk to aluminium engenieering in brokvale, and the boys a bob jane broovale always fit tuff tyres and stretch on mine and they also have metal valves for free but not sure if thats close to you??
    if it is u gota come meet me i wana chack ur 86 and we can do a palmy run
  • #6
    im located in ryde area...
    btw .. i got it wrong .. its long champ... not equip
    tire size is 195/50/15 the rims are old ... its from a mate.. its work well with the old doggy tire before putting the new tire on it. sign...
    where abt the place in brokvale ... open on sat?? whats the damage $$ ??
    any idea ... what's the issue or the tire is stuffed??
  • #7
    Jason
    Nundah
    How long has the tyre been on the rim.???
    Have you driven on it yet.??
    The front runners on my drag car kept goin flat in about a day and half after gettin them fitted...
    Once I drove on them they were fine...
    Stayed up for ages...
    If you had a tyre on there before and it was all right I'd be questioning the new tyre you put on... Did they replace the vavle when it was fitted.?
    I've had a vavle play up on me befor...
    I ended up just pumping the tyre up to about 50 psi the sticking a pen it there to let the pressure out then pumped it up again and was golden.. Was most likely just a bit of shit in it...
  • #8
    have the new tire tire for a few days... the loss of pressure happens the very next day after fitted... went back today ... and tested and changed the valve again... but pressure still leaks from the gap between the tire and the rim... they just claimed that its a old rims ... and old rims have this issue... gees..... i think they have no idea...
  • #9
    Jason
    Nundah
    Yeah.... definatly sounds like it....
    Go some wher else..
  • #10
    shaun
    nsw
    avalon
    oh like these
    place in brooky in on pittwater road, call them they'll direct u 02 9905 0481
    they fitted my tires no probs and can put in new valve free wit $10 to fit tire prob??
    otherwise if is bent and needs re rounding call alli engineering 99396319 anywhere from 60 to 180 with ploish depending how bent it is...
    if u give up i'll buy them off you
  • Page 1 of 2 1 2 LastLast
    1. bent rim
      By whatcamber in forum Technical - Questions
      Last Post: 15th February 2011, 03:46 PM
    2. rim widths
      By kurtis in forum General Topics (No Technical Questions)
      Last Post: 3rd February 2007, 10:36 PM
    3. do u like to rim?
      By dori_86 in forum Technical - Questions
      Last Post: 16th November 2006, 10:26 PM
    4. Rim Width
      By Rallystanza in forum General Topics (No Technical Questions)
      Last Post: 27th April 2005, 11:17 PM
