Results 1 to 10 of 83
Thread: best money spent to give the 20v more ballls
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    Default best money spent to give the 20v more ballls
    so i dont realy know much about na power so heres my ideas, want it to rev to 10g just for my novelty. will get all the basics of a rebuild rings seals bearings.
    please correct me if/where im wrong
    so st20v
    microtech ecu thats already there
    keep std cast pistons (ive had heeps of issues with pistons and seems toyota engineers get it better than a/m doods)
    balance thats for sure
    lightened flywheel already got one
    trd.5mm?
    shave head for more comp?
    heavy valve springs? what brand
    cams? what brand?/duration/regrind?
    gonna keep vvt on?
    exhaust kazien g extractors, what diameter exhaust?
    any other ideas additions welcomed, engine in my street car replacing 130kw 4agte.
    AE86 THE BEST
    Veteran shift_rook's Avatar
    SE Burbs
    to keep the vvt in effect the highest duration you can run is a 272 on the inlet side, pm sam q, he knows a fuck load bout the 20v, definately keep vvt, balancing everything is also a great idea and standard 20v pistons are fine as long as you're not turboing past 8-10psi. microtech is the best thjoing you can do for it i wreckon
    SE Burbs
    also could chuck it on a 7afe bottom end for more torque, it's what i'm doing and not an expensive mod, hell i got my 7a short motor from the wreckers for $80
    Jonathan
    To rev to 10g:
    (or to 9g and see what happens after that...)
    Different cams would be a must. Probably just as big as you can buy. Toda or Kelford. Maybe 305 degrees duration, but 288 degrees will work also.
    Upgraded valve springs, from Toda or Kelford as they advise.
    Upgraded con rods or conrod bolts at the very least.
    Remove VVT. Get good adjustable cam gears.
    That's probably all you need. Make some carefull notes about how the cam gears are positioned. There is no 1 correct spot, but you need to know what your doing, and need to experiment.
    Then it's just software tuning.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    paint the cam covers with flame air brushing
    FTP.
    Anthony
    Quote Originally Posted by Jonny Rochester View Post
    To rev to 10g:
    can you have both vvt and have aftermarket cams?? because thats my next step in my motor
    or is it better to run good adjustables instead??
    West
    Cost more to work a 20v as Im sure you know. Especially atmo.
    Id suggest forged rods and pistons if you're really keen. Then get an ecu that runs better than a microtech on atmo tps type tunes.
    Id suggest the little motec m4, or Adaptronic e420c. Then get a really nice tune, by a really good tuner, makes a lot of difference on a 20v to have a good tune. Cam it up if you like but you'll lose vvt and spend maybe 2k and make it a bit piggish down low. Will put a big smile on your face, if you like revs. You will expect the oil pump to fail before 10000rpm also. You might be able to push this figure higher with electric oil pump assistance. Best to dry sump it if you want that sort of rpm. there is a guy in Australia making dry sump setups for them but be prepared to spend 4-5 grand.
    In reality the only way to get real torque from the 4age range is to boost it.
    User fantapants's Avatar
    Pat
    isnt this just for a street daily ed?
    if so forget the 10g engine mate, you allready have a fast car, amke this one fun Absolute best thing you can do right now is sack the microteck and get the motec or adap and the very best tune posibble. There is a massive difference in the quality of these engines when going from a shit tune to a well sorted tune
    You can do cams and keep vvt, toda do a good selection, also have seen good gains from the toda 421 exhaust manifolds. Silvertop heads also have harsher casting in the head. Keep the revs at 9g max, power peaking a 8gish and it will be a blast to drive.
    my two cents.
    also talk to magic man i think, he had a 130rwkw blacktop engine i beleieve.... he has a great knowledge base to pick from
    06/07/2011
    Eddie
    sa
    yer streeter realisticaly youre right and thats why i took the turbs engine out not nice to street drive. microtec will never leave i love them too much. thanks for the input tho
    AE86 THE BEST
    Jonathan
    Quote Originally Posted by AEA-386 View Post
    You can have vvt with some aftermarket cams. You can't have VVT with TRD cams as they accept normal 16v style gears, but you can with Toda. But he had stated 10,000rpm. So I figured you would want some fairly agressive cams to make any power up there, and with such big duration and overlap I wouldn't be taking chances with VVT. Not untill you did a lot of testing and research yourself.
  1. KE70 Corolla Loads of money spent!!
    By Miniman_Alis in forum Cars for Sale (Toyota Only)
    Last Post: 17th January 2013, 09:19 AM
  2. 200rwkw AE86 turbo 20v big $$$$ spent
    By trb20v in forum Cars for Sale (Toyota Only)
    Last Post: 7th November 2011, 08:11 PM
  3. 20v engine package, wheels, cage, need money asap
    By ph fat in forum Car Parts For Sale
    Last Post: 18th May 2009, 06:30 PM
  4. how much have you spent
    By TURBO in forum General Topics (No Technical Questions)
    Last Post: 12th September 2005, 04:22 PM
  5. so how much have you spent
    By Luke-tc16 in forum General Topics (No Technical Questions)
    Last Post: 8th June 2005, 10:41 PM
