Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: which fuel is best for your ae86???
    Senior Member JDM_KING's Avatar
    jake
    West Side
    Default which fuel is best for your ae86???
    hi i was wanting to know which fuel works best for your ae86 all opinion would be valued.
    thanks
    Veteran shift_rook's Avatar
    SE Burbs
    bp ultimate, everyone i know who is into cars likes it, apart from that maybe some good mobil, definate no no for shell
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    e10. easily the best fuel for any 80s car
    FTP.
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by JDM_KING View Post
    thanks
    It will depend on your individual setup, which motor your car has, how much compression and timing advance you're running, what kind of cam/cams etc etc
    But VERY generally speaking, 98 octane will be best for your car. I recommend BP ultimate.
    todd
    another BP ultimate here.
    Kieran
    Going a bit off topic here...
    I have always run my 1jz supra on ultimate cause I was told it good for it
    Just wondering what will happen if i dont? Its just that when i drive it hard there is quite a noticeable difference in price as she is a thirsty beast.
    Josho
    Quote Originally Posted by squish_m8 View Post
    Lower octane fuel is more likely to pre-ignite, as such you have to 'wind back the wick' (such as retarding timing or lowering boost levels) in order to prevent damage to your motor (especially if modified), such as pinging and detonation. Detonation kills motors fast.
    Obviously this isn't an issue with standard motors as they are designed to use the lowest quality fuel in the region and run fine, but will run better on higher rated fuels (unless they're designed to run on leaded / some new euro cars have 95/98RON minimum).
    Also if your vehicle has been tuned on 98, running it on lower octane fuel is probably about the best way to do as much damage to it as possible. If it's set up to run high octane then fucking stop being a jew and run high octane in it.
    Newer vehicles with OBD2 and constantly variable fuel trim / timing adjustments actually adapt to the fuel you put in them regularly by 'seeing' detonation / knocking thresholds and adjusting mixtures, timing and such accordingly. Great in theory, actually, in practice as well. But it's a slow learning process, so if it learns to work with 98 all the time, and then you put a tankfull of 91 octane in it... it's going to ping it's head off all the way to the dealership when you say 'what the fuck is wrong with my car'.
    anyway, rambles.
    My corona pings on 91 but runs sweet on 98 (it is designed for leaded fuel, lol)
    jake
    West Side
    y definate no no for shell ? i thought v-power was good???
    Veteran Wally's Avatar
    Havent bought petrol for over 4 months. but BP Ultimate is what I ran (4ag Bigport)
    4AGE 16V
    Josho
    I have had quality issues with both caltex and mobil. I.e. water in fuel / so low quality it'll cause my car to ping under normal driving circumstances
    Minor issues with shell, but i'll use it.
    BP / Liberty ftw.
  1. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  2. AE86 rear bumper/AE86 fuel tank/universal seat rail.
    By drift kid in forum Cars or Parts Wanted
    Last Post: 21st December 2010, 10:24 PM
  3. Replies: 2
    Last Post: 5th April 2010, 06:54 PM
  4. fuel rail adaptor plate for aftermarket fuel pressure reg
    By 1sik20valve in forum Cars or Parts Wanted
    Last Post: 5th January 2010, 02:18 PM
