Results 1 to 7 of 7
Thread: high idle, please help
    callum
    qld
    tully
    Default high idle, please help
    ok. i just did a turbo conversion and all is good. after a few days of driving normally i took my mate for a spririted drive and when we came back the idle of the car was really high, i let it sit for a few hours then started it again and yea still idls high.
    any suggestions as to whats causing it?
    cheers.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    happens to my car but mines jus 4ag n/a, if its same problem as mine check idle screw or ur throttle cable could be sticking somewhere like mine
    callum
    qld
    tully
    ill check that as soon as some ones home to help me open the bonnet. but would it just happen all of a sudden like that? i held the throttle wheel thing down as far as it would go so i dont think its the throttle cabel sticking.
  • #4
    my car had same problem and could never figure it out, sent it to get tuned and the guy fixed it though the ecu, possible fuel mixture when idle?
  • #5
    Dave
    Western Suburbs
    im not sure champ like i got the same problem, today i had a long drive on like a 30 degree day, on idle goes up to 1500, then if i tap it up to 2 then it will idle on 600
  • #6
    Gone
    Joel
    Picton
    Try some WD40 on the throttle linkage and the cam and give it a gut full of carbi cleaner, my mini and dato use to do that it's a pain , I think just with all the extra heat and metal expansion something mayb catching. Worth a try
  • #7
    have a look at all your hoses on your inlet vaccume or mayb inlet gasket is gone
  • Similar Threads
    1. 16v small port high idle
      By KAYE70 in forum Technical - Questions
      Last Post: 20th May 2012, 06:23 PM
    2. *SOLVED* - Blacktop 20V High Idle
      By 70XIN in forum Technical - Questions
      Last Post: 24th October 2010, 08:23 PM
    3. High idle - the endless saga
      By Golberg in forum Technical - Questions
      Last Post: 4th May 2009, 08:19 PM
    4. 4age HIGH idle
      By stylz in forum Technical - Questions
      Last Post: 27th July 2008, 08:39 PM
    5. help with high idle
      By DriftPlease in forum Technical - Questions
      Last Post: 14th January 2007, 06:11 PM
